MY cell phone battery is not charging.whenever i plug my charger to the cell phone it shows the battery is charging.It shows 1 cell is available but no matter for how many hours i charge it still stays @ 1 cell.I tried charging it with an portable international charger the battery was fully charged but it drained out in just about 2 hours.HELP!!
SOURCE: correct procedure for charging battery
Batteries no longer have a memory problem so charge away. I plug mine in every night and have never had a issues.
SOURCE: LG KG800 charging problem.
Hi Robert, actually its LG and the batteries are the worst - i did the same thing with my brand new shine! You need to be careful when you start a new battery - make sure you drain it 100%, then charge for 6-8hrs, then drain 100% then recharge - after that you are good.
a new chocolate battery goes for $25-40
thanks
SOURCE: My daughter's LG EnV charging port
You can get a charger at factorydirectcellular.com. The link is
http://www.factorydirectcellular.com/home/universal/universal-battery-only-charger.htm
The charger charges the battery independent of the phone. It is the only one I have found and it works GREAT. I had a couple issues at first but the rep, Matt, bent over backwards to resolve them. I would recommend this charger and company to anybody. The charger is a universal charger and will charge other cell phone batteries as well. The only con is that it does take a little longer to charge than using the port.
SOURCE: Battery not charging and overheating very quickly
actually.. our indian electricity as 240volt and 50 hertz..
and united states electricity as 110volt and 60 hertz.. i think you aware of this...this makes changes i think..if u r not aware try google search abt electricity IN america and india...
1.take ur mobile and go to LG showroom nearby and ask about this problem..
2.and we can have better converter for this type of mobiles...
"try asking in famous electrical and electronics shop.."
if the battery is suddenly discharging thats seems to be duplicate battery .. try buying original battery that cost more....
"DONT FORGET TO RATE THE SOLUTION "..
SOURCE: wireless phone wont stay charged..loses battery
Repace battery in LG cell phone with a Ray vac batt and go down
while not using phone
