Boating Logo
Posted on May 10, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 1988 bass tracker ingnition switch won't
Gordon Richard MacLean
Level 2:
Champion:
  • Expert 253 Answers
  • Posted on Jul 14, 2014
Expert
Level 2:
Champion:
Answers
253
Questions
Helped
77368
Points
481
Hello cainld04,
Sounds Like The Start Solenoid Is Not Working.
When You Turn The Key To Start You Should Hear A Click ,If Not Solenoid Is Probably Bad,If Yes Then Starter Needs Service.
Hope This Helps.
Gordon
2 Related Answers
Anonymous
  • 77 Answers
  • Posted on Jul 02, 2009
SOURCE: mercury outboard 60 motor turning over but not firing up.
get some starting fluid and spray a liberal amount into the air intake, then try to turn over. if it will not turn over with starting fluid you have a problem either with your ignition system, example: plugs, coils, wires, ect. If it does fire and then die out with a shot of starting fluid then you have a carb problem. If the boat has been sitting anything over a month thats where I'm betting the problem is. Post back after you find out if its a fuel, or fire issue and we'll start the repair process.
Anonymous
  • 2926 Answers
  • Posted on Aug 07, 2011
SOURCE: I have a 94' Mariner Tracker pro series 60hp, it
It seems like the ignition key is suspect and needs to be replaced. The ignition could be preventing voltgae to the stator and ignition coils. See if you have battery voltage from the terminals on the ignition switch by using a voltmeter. If there is voltage from the ignition switch, yoy may have a bad stator that is causing a no spark condition.
How do you start 1993 bass tracker?
Bass Tracker? Bass Boat? If its a tiller motor, yank the rope until it starts, or, your arms fall off, whichever comes first! If its electric start, check your batteries are good & fully charged. Make sure your "kill" switch is connected & you're in neutral. Turn the key. In fact make sure you're in neutral for the tiller motor also.
Bass Tracker 190 tx won't start. Battery 100%. Fuses good. No power from ignition to motor
Check for inline fuseable link on harness between switch and motor ..also check ign switch itself.
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
Headlights not working
It's grounding out after there open trace the wires looking for exposed or broken wires. Or run new wires
Grounded out wires and it won't crank over
A/T or M/T transmission, they are wired diffr.!
I guess, you know flashing is bad wiring , right?
but this no crank page solves this.
takes only $20 voltmeter to be , effective.
to crank takes but 1 wire. (starter good)
the ST line or start line.
suzuki calls this 1 wire the Start line, (amazing fact)
at the key switch a black-red wire.
then after passing through the (clutch/ or A/T park switch)
the color changes, 1 time to blk-yell, then lands on the starter.
its very simple and fully show here, in details.
http://www.fixkick.com/nocrank.html
2answers
I have a 1988 olds cutlass ciera 3.8......my problem is the car won't start......cranks over just fine but ain't fire...it has spark, fuel pressure, and the timimg is good and the wiring seems to...
Hello
The engine and transmission in this cars drivetrain are fully electronically controlled by a computer called the PCM (Power Train Control Module). Whenever a problem like this occurs the computer stores a record of the problem in the form of a fault code in its memory, to read these fault codes you must have the systems memory scanned with a special tool. Once the fault code(s) are read you then must perform the appropriate diagnostic testing to find and resolve the problem(s)
1988 jeep won't start
Not sure if I read your post right, but you have to have a hot wire to the ignition switch from the battery, independent of anything else on the car, before the switch will work.
The CPS is a common problem on the jeeps, though. If bad, you may not get a coil signal.
1991 Honda crx won't start
Try tracing the wires and looking for a worn spot in insulation that is grounding out, its a royal pain but might be the only solution, use wire prob and test areas where inaccessible. good luck
1988 bass tracker manual
Power trim tilt switch//on throttle control//instructions to replace needed
Bass tracker fuse descriptions
I was trained at a tracker dealership and that is one of their faults. The best way to find the fuse for the bilge pump is to look on the back of the bilge switch and trace a wire to the fuse panel. Most of the time they are color coordinated so you can match fairly easy without trying to manually probe for the wire.
Jun 10, 2009 • Boating
Top Bass Pro Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Bass Pro Boating Expert? Answer questions, earn points and help others
