Is it normal for quiet operation? how much suction can i expect? it lightly feels like suction when i put my hand over the nozzle...
I took mine completely apart, removing every screw to get to the motor which was full of lint, hair and god knows what. I removed all the debris I could by hand, put it back together, and it works like new. I think debris gets in if the filter part is pushed too far down and the hole in the cup is open to the top part. My husband wanted to throw it out but I figured "what the heck". It's broken, it won't get more broken if I take it apart, it's only a year old.
SOURCE: electrolux power nozzle not working
FIRST OFF EACH OF YOU HAS A COMPLETELY DIFFERENT MACHINE. ESPECIALLY THE OXYGEN WHICH IS MADE BY THE "NEW" ELECTROLUX. THE OTHER TWO ARE MADE BY THE "OLD" ELECTROLUX WHICH IN NOW CALLED AERUS. THE ADVICE WITH THE GUARDIAN TO GET IT SERVICED BY THE DEALER SINCE THE POWER NOZZLE IS PROBABLY STILL UNDER WARRANTY IS A GOOD IDEA. (THE 25 YR. WARRANTY DOESN'T APPLY TO THE WHOLE MACHINE SO YOU HAVE TO READ CAREFULLY WHATS COVERED. THE MAIN MOTOR DEFINITELY IS.)
ASIDE FROM ALL THAT
DID ANY OF YOU HIT THE RESET BUTTON ON TOP OF THE POWER HEAD?!
SOURCE: NO SUCTION
If you have no suction, there are only a couple of things that could cause it. As you have checked for blockage, and changed your filters, you may have a vacuum motor with bad bearings, or broken fan blades (inside/on the vacuum motor). Either symptom points towards a vacuum motor being bad and needing replaced.
SOURCE: Does not have enough suction
Remove hose and try running hot water through it. check filter at base of bag holder. Last is could be clogged impeller attached to motor.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
SOURCE: Electrolux model 2100 shuts off with slightest suction blockage
This is exactly the symptom you would expect from a defective bag control valve. The actual control valve sits under the dial on top of the vac and often cracks internally. It can be replaced in about 15 minutes by a good tech with genuine parts from AERUS Elctrolux dealer or repair center.
You can open the vac front to rear like a **** shell by sliding the bumpers out the front with the bag door open, however you must be careful not to disturb the wiring harness and to mark wiring locations. The body must be carefully realigned for closure. If it is not perfect you will not be able to slide the bumpers back in.
SOURCE: my electrolux epic 6500 power
No. If the power nozzle motor is running, then a new belt will do the trick.
