There is no call waiting tone and when people try to call in they get a busy tone. I tried 7311# and 7321#
SOURCE: line not assigned
Somewhere, floating around, is a TDA Users manual. Program 19 and 20 deal with Idle line preference out and in. You could have a couple of things going on, one is that you lost your ILP, or the line assigned to it is no longer there. If it's the former, try this:
PROG 19 0 is no line 1 is Idle CO 2 + a button is that line, and 3 is intercom. Press STORE after the sequence and try it.
Worst case is you do 19 3 and get it to the intercom on idle.
For incoming PROG 20 0 is none, 1 is longest ringing, and 2 plus a line is to prefer that line, used when you have a private or semi-private line that you need to answer. Again, press STORE to save your selection.
HTH
Carl
PROG 19 0 is none 1 is
SOURCE: How do I get "call pickup" to work on a KXTES-824?
Two of the above codes work for me, so let's figure out what you're doing. First of all, did you convert the intercom calls to ringing on all calls? If I have auto answer turned on, I can't pick up anything.
If the phone is ringing, I can use 40 and 41xx to pick it up. I can retrieve a call from hold by dialing 53x where x is the line number on hold (just in case you're trying this with a cordless or single line set).
By default, all extensions are in pickup group 1, but 41xx directed call pickup will always work if the Call pickup deny is properly set as you indicated
Carl
