Samsung SyncMaster B2030 20-inch Widescreen LCD Monitor - 1600 x 900 - Logo
rajesh Posted on May 09, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dead pixel
I brought my monitor 8 months back till now there is no problem but recently a black dot appeared on the screen i thought it is some dust and cleaned it but it didnt disappear then i conformed that it is dead pixel does my warranty work or not.
Anonymous
Level 3:
  • Samsung Master 6,771 Answers
  • Posted on May 09, 2012
Anonymous
Samsung Master
Level 3:
Answers
6771
Questions
0
Helped
1777287
Points
21413
It might, somes companies won't honour warranty unless you have 3 to 5 dead pixels. Go to www.samsung.com and contact customer support to see what can be done.
3 Related Answers
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Aug 01, 2007
SOURCE: horizontal pixel line
I have seen this B4 here is a link that may help. http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Jan 05, 2011
SOURCE: Hi, I have Samsung SyncMaster 920NW 19 inchs LCD.
That is LCD panel problem, you can try reseating the ribbon cable between the logic board and the LCD panel just to see if it will come an go. Also check all the electrolytic caps.
Download service manuals here:
http://elektrotanya.com/?q=showresult&megnev=SAMSUNG&megnev2=920&kategoria=monitor&kat2=schematics
You can learn more here:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Anonymous
  • 531 Answers
  • Posted on Aug 25, 2011
SOURCE: My brightness monitor appears in
Hi
It's likely you have a sticky button.
Look carefully to see if you have a Menu button, enter the control panel and use the arrow buttons to scroll to the exit icon and then press menu again to manually exit.
I hope this helps.
4helpful
2answers
My tv screen has a black spot
HI,
Are you sure that there is balck dot on the sreen. Check one more time is it any dust on the screen.
Black spot Means pixel of the Lcd sreen is fault. There are thousands of pixels in an lcd screen. when any of the pixel or a group of pixels become faulty the black spot will appear. Its not possile to rectify the problem other than replacing the LCD panle if its avilable. The avilability of lcd screen is very rare.
Ajin
It has more than 10 black dots
Your LCD screen therefore has more than 10 dead pixels. The pixels have died and will not come back to life. If this monitor is under warranty you will be able to claim warranty support.
If this is not the case and the pixels are destracting, you may get a LCD technician to replace the LCD screen. Another option is to purchase a new LCD monitor.
Take care!
damnor01
2answers
I have a green dot on my flat LCD TV, how do I get rid of it?
At the LCD pannels may appear dead pixels. You can not solve this problem.
If your monitor is in the waranty period, you can address to your vendor to see if it's possible to replace your monitor. Every LCD producer have own waranty strategy.
1helpful
I HAVE RED DOTS ALL OVER ANY BLACK COLOR OF THE PICTURE
Could be whats known as dead pixels, this is tested be showing up a black or white screen. Microsoft paint or word will do. If an area always has dots then dead pixel. However if it doesn't constantly remain a dot then, some-thing else. Dead pixels come about due to age.
A technician will be able to diagnose your problem by performing white screen test.
damnor01
What does it mean by dead cells?
I assume this is related to your LCD monitor.
I think you mean dead pixels. The LCD monitor has tiny pixel elements, one for each red, blue, green color and each one of these colored pixels are turnes on by a transistor. When a transistor fails then the colored pixel it controls does not light up. This is a dead pixel and it shows up as a tiny black dot.
If the screen displays a blue screen, a dead blue pixel will appear as a tiny black dot in the blue screen.
You normally would not notice a few dead pixels unless they are grouped together.
6helpful
2answers
I have black spots on my monitor screen that seem to multiplying.
The black dot will just grow until the rest of the screen fades.
It is pixels dieing in the monitor
2answers
Black spots appeared on 17" LCD Monitor-SyncMaster740N
you might have what you call "dead pixels" or a "stuck pixel" try a simple test like this one now it is not the most creative one, but it does help to see if that is the case. u might be able to Fix a STUCK pixel, but unfortunately you can not fix a "DEAD pixel" simply because it is DEAD.
try this website for simple fix instructions.
if is dead pixel what you have, if u can live with it, great, if not , it might be a good reason to get yourself an another monitor.
Good luck
Sony a100 distortion dots - Im getting several
If these are single pixels on the LCD screen, they are normal. From pg. 8 of the user's guide:
"The LCD monitor is manufactured using extremely high-precision technology so over 99.99% of the pixels are operational for effective use. However, there may be some tiny black points and/or bright points (white, red, blue or green in color) that constantly appear on the LCD monitor. These points are normal in the manufacturing process and do not affect the images in any way. "
This may also be helpful.
"images may trail across the LCD monitor in a cold location. This is not a malfunction. When turning on the camera in a cold location, the LCD monitor may become temporarily dark. "
Blackspot on screen
is it a tiny black dot? about one pixel? That is whats referred to as a dead pixel it happens on LCD nothing can be done of it but to replace the LCD screen. Usually you can just bare with it and wait til there are a few dead pixels before worrying about it.
Thanks,
Lee
Monitor
Sylvia,
It's seems you had a stuck pixal... Turn your monitor off and try this tips: Wn't work in every case. It may take a few attempts to make sure you are pressing exactly on the dead pixel.These instructions will fix "stuck" pixels, not "dead" ones, like red, blue or green. An alternative, but similar technique involves gently massaging the stuck pixel with a warm damp soft cloth.Alternative technique to tapping: Using a rounded pencil eraser, push with moderate pressure into screen at stuck pixel.
Good lucks!
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
