I had a paper jam and even though I cleared it the printer kept telling me there was a paper jam; since the toner was also low I replaced the toner cartridge as well. this is the first time I have replaced the toner cartridge on this unit. After replacing the toner cartridge the paper jam problems went away; however, each page as a line of half-moon shaped smudges down one side. Can you help me figure out how to get a clean print? thank you, Grace
In case something winds up sincerely with your Dell printer, you endeavor to fix it isolated or you go in neighborhood heading which you dependably find excessive and not 100%. Thusly, we brief that you can get called "One Search Point" gave by us. We offer a smart number that you can call and trade with the Dell expert on the phone and discussion about the issue with your Dell printer. Inside a minute, your pressure will be grasped and in case it requires further support, by then you are given that what's more
Dell Printer Support Phone Number.
https://www.onesearchpoint.com/dell-printer-support-phone-number/
SOURCE: diagonal lines on print
Follow these steps.
Print Quality Problems on 3010cn.
Reset the NVRAM On the 3010cn
To reset the NVRAM, perform the following steps:
appears, and then press the (right arrow) button on the printer or (Set) button.
SOURCE: Not printing extreme right side of page
It is either your drum or open front cover see blue handle @ right hand side pull it out look at rignt hand side of printer and a door has opened (only small) pull the blue lever out and move the pad back andforwards a few times this cleans the glass.
It worked for me but I have to do it fairly often but it samve buying a new drum etc
SOURCE: Pages full of toner / toner streaking
First off, this is a comment from a random person who may or may not know ALOT about these printers and toner/printer design in general. All toners are not designed to the same specification. Toner is a combination of plastic "pigment" and iron like shavings to make it magentically attracted to the electrical charges within the unit. Different toners conform to different grades and mainly size of the particles within the blend. The manufacturer doesnt only recommend that you use their toner to make them money, yes of course it makes money, but its because when the unit is designed it is designed to use a certain grade of toner, trust me if you put the non-branded toner vs the branded toner under a microscope you would see quite a difference. Often the non-branded toner is much larger in particle size (obviousely because its cheaper to make at this spec). This causes a variety of issues from excess toner not being cleaned off of developer rollers, IDT rollers, or clogging of toner dispenser tubes in the unit and the micro filters contained at the toner dispenser assy and developer assys. Also as for the issue not changing when switching to dell branded toner - the dispenser tubes within this unit contain up to 500-1000 pages worth of toner, making no change in toner you make immediately visible. Also depending on the damage caused by the previous toner, it may not be able to be fixed until all the components in between the toner and final delivery (drum cart) are replaced. In this case more than likely the toner dispenser assy, all developer assy's, and drum cartridge need to be replaced, and than be sure to stick with factory branded toner :)
SOURCE: laser scanner on dell 5110cn laser printer, prints black smudges
replace fuser. How far apart is the ghost image?
SOURCE: Dell 1720dn takes extra blank page at end of job and jams
There are rubber rollers that grab the paper to pull it through typically these get slick over time and will cause the printer to grab an extra sheet of paper. How I usually fix this problem is to check and see if the rollers are slick if so then I take an Emory board to them to rough them up just a little bit. I have also in the past used clear finger nail polish on the roller and that has helped. I would apply a bit of the clear polish to the roller, if it did not work then I would take the Emory board to it.
