D945gcnl mother board, directly it opens cmos setup page, give save & exit it appers (turn off power and reinstall the jumper in normal mode position) what can be done?
Some MB's have a second jumper setting on the board to allow a technician to jump to a faster "trouble shooter" configuration. After any or no changes are made to the BIOS's configuration the BIOS wants the The tech to reset the jumper back to "Normal Mode" so the customer doesn't have an overclocked or "hyper"machine voiding it's warrantee. I have seen this on some mostly older boards including Intel's who are known for down speeding their MB's. Check the websit for the MB's manual and see if it tells you where the jumper is located. If not, Also try to update the BIOS to the latest version and this may resolve your problem. Hope so.
Shut off your computer, open the side case and touch the metal to ground yourself before taking out the power cord.
http://support.gateway.com/s/PC/310_Series/Shared/2520578/2520578mv.shtml
I
guess your motherboard is this? Find the "N" on the picture on your
motherboard, should be a 3 pin jumper (closer look if your click "BIOS
configuration jumper"). Now, move the jumper (blue block thing in the
picture) and place it on pin 2&3 and wait a minute. Then place it
back onto its normal position, pin 1&2.
Solved?
Please turn off the system and reinstall the jumper to normal,
INTEL BOARDS ARE VERY SENSITIVE TO THE VOLTAGE OF THE CMOS BATTERY!!!
let me guess: 3-5 years your computer works fine, and then... BOOM: "turn off power and reinstall the jumper in normal mode position" ?
CHANGE THE BATTERY and this will solve the problem.
after switching on it will go to the BIOS once more - you should set up date/time etc; after selecting "save settings and exit" it will write that phrase "turn off power..." again - please don't be afraid!!! and after switching it off and then on - it will work fine.
Good luck! =)
Michael Adamson
Fiend your solution direct from intel. Here is your solution....
http://www.intel.com/motherboard/prob676ijt65/solution
123
I faced the same problem,like yesterday.And it took me 6hrs to search for the real solution to my problem and fortunately,found it here:
http://www.techyv.com/questions/how-reinstall-jumper-normal-mode
Hope it works for you too.
SOURCE: turn off power and reinstall the jumper in normal mode position
If I understand what you are asking: The computer starts up and you see the setup page. It then says that you are supposed to place the jumper in the normal position. It happens every time. The jumper is at correct position
Try to clean the pins on the board, check the connection inside th jumper. (with multimeter or else). Try to clear the bios .
If this is correct, it is telling you that there is a jumper on the motherboard (probably labeled "clear CMOS) and it's set in the incorrect position. There will be three pins. The jumper is installed across two of them. Move the jumper (the little plastic thing) to the other setting: for example, if it's installed on pins 1 and 2, move it to 2 and 3. Give that a try. Will probably work for you.
Any solution yet? same problem. Turn off power and reinstall the jumper in Normal mode position
turn off the power and reinstall the jumper in normal mode position,
do not come on to the windows, i have done it many times but again it goes directly to the bios.
someone know about it ???
After powering on system automatically goes to BIOS after if i save & exit the BIOS it is showing msg,that is "Turn off the power & reinstall the jumpers in proper mode.
Please help me.
"turn off power and reinstall the jumper in normal mode position"?
what is this & how to solve it?
