Does it have an icemaker? Was the water line plastic tubing or copper? If plastic, it could have been dried out and cracked by the heat from the motor.
Hi, The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light. There are a few things to check before resetting the control. -The unit not being level so both door switches do not make contact - The sump plugged up so water is not pumping across the heater (see sump clean out below) - Not enough water filling the dishwasher - The heat element is not working To reset the control use this key dance within 5 seconds press:HEATED DRY, NORMAL, HEATED DRY, NORMAL This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use. Thank you !
The KitchenAid KGYS750GQ0 is a gas dryer, so the solution of looking for a heating element is not helpful. There are several heat switches and a gas burner assembly (which includes a gas valve and an electric ignition), any of which could be the problem.
If it is tumbling. This troubleshooting video will help. Could be the thermal fuse,ignitor,or gas coils. The free video will walk you thru testing. www.appliancehelponline.com/servicemanual.html
Do you have the part number, is so Put in (Find kitchen aid dryer Part# 111111* ) Or( Find kitchen aid dryer heating element* ). If this is a old dryer some parts are not made anymore. Any Dryer over 7 years old is no longer energy efficient. Hope This Helps.
After checking all sprayer arms for clearance, and checking heating element and discharge pump, the problem was solved by replacing the small sprayer arm at the top of the washer. This small arm had popped off some time ago - obviously the water pressure was excessive for the small and unimpressive fastener. Luckily we had saved this piece, which I refastened with a strong aluminum non-corroding small bolt. Presto - now the water distribution is back to design specs, with sufficient water coming out under pressure from the mid level arm. Lesson: always look for the simplest cause first with the simplest solution. TCA
