We just bought a house with a pool recently emptied and refilled the pool we have a sand filter system with the dynamo pump but no manuals on how to start it up
SOURCE: motor feels bound and hard to turn...
If there is a capacitor on it, you could replace that. If there is no capacitor the starting switch is probably broken. If you are not used to working with electricity, either have someone qualified work on it or...BE CAREFUL!..God luck...Lee
SOURCE: how do i remove the impeller from a dynamo pool
WITH LOTS OF LUCK . THEY SCREW OFF(OFF TO THE LEFT LOOKING AT THE IMPELLER SO COUNTER CLOCKWISE ) VICE GRIP OR SCREW DRIVER ON SHAFT TO HOLD IT, THING IS IF THE SHAFT IS RUSTY YOU HAVE A REAL GOOD CHANCE OF BREAKING IT AND IMPELLERS CAN BE HARD TO FIND.. THE SEAL SHOULD BE # 1000 FOR THAT PUMP... BEST OF LUCK.. J
SOURCE: The pot on my Dynamo pool pump tightens in the
I'm assuming you mean whe you thread the strainer basket pot into the pump and tighten it it ends up being 90 degrees off center? That means you cannot turn it and additional 270 degree. Unthread and wrap multiplul wraps of teflon tape onto threads. Then I'd add lightly add some pipe dope. Tighten the assembly up, but stop when it is snug and aligned. The combination tape and dope should keep it from leaking, but remember this would be a suction leak, so check carefully
