I had irreplaceable pictures of my sister who passed away on it and i wanted to know if i could change the video from the samsung to another screen. I have an iphone 3g screen and some nokia screens. Is there a way to soder? or wire? the screen to the samsung to retrieve those pictures?
Displays from one phone brand to another are not usually able to be used in another brand, kind of like trying to put a Ford engine in a Chevy.
You should try to connect the phone using a USB cable (the charging cable) between a PC and the phone. That usually auto-mounts the phone as an external drive of the PC.
Then you can browse to the folders on the phone where the photos are and copy them to the PC to preserve them.
If you don't have a PC, perhaps a friend has one, a laptop or desktop, Mac or Windows, shouldn't matter which, and they would help you copy the photos.
If I were doing that for a friend I would then burn them to a CD or DVD as data to save them, or make a video slide show of them to play in a DVD player, or both.
Sorry for the loss of your sister. Hope these ideas help.
The only other options are a screen repair by a qualified tech or a phone uograde. Most carriers will copy your data to a new phone during that process, and you would want to explain how important the photos are to you and verify they survived the transfer ok.
SOURCE: samsung A707 Sync
i know how to solve it this happened to me too. you take off the back, get the battery, and barely put the battery part against the inside part (as if you were putting your battery in) just barely touch it a few times and it should work. im sorry if this doesnt work
SOURCE: Instructions to replace LCD Screen on Samsung F480 (Australian)
http://www.formymobile.co.uk/toccodisassembly.php
this is the only guide i can find :)
SOURCE: i cant get the alarm clock picture of my screen of my samsung
Open the folder (widget) indicated by the arrow on the left of the main screen and drag the Alarm Clock icon into the folder.
SOURCE: i i forgot my phone lock code for my samsung sgh-f480
hard reset *2767*3855#
All Samsung Hard Reset Codes
In those steps:
1.)*2767*3855#
2.)*7465625*638*00000000*00000000#
3.)#7465625*638*00000000#
Now your phone is unlock forever Permanent
Here is Samsung F480 Secret Codes
Admin Settings: *#6984125*#
Admin Settings
Internals (sub menu): *#9072641*#
Developer Settings: *#0523#
Camera test mode:
Press *#36287# key string in the dial screen to enter camera test mode -
[1] Auto focus [On]
[2] ISP firmware write
[3] ISP firmware version check
[1] Press the "1" key to disable auto focus. In order to enable auto focus, press the "1" key again.
[2] Press the "2" key to write the ISP (Camera Module) firmware. “ISP firmware write [Please wait]” will be displayed during 2 minutes. Then "ISP firmware write [SUCCESS]” will be displayed when the firmware upload finished.
