Led on control panel does not light and don't know present temp inside
SOURCE: Frigidaire Upright freezer with Beeping Display
First make sure you have a good 9v battery installed. If it is ok then the problem will probably be in the display board or the wiring connectors between the boards. CE is communication error. If your model has the electronic tempature control instead of mechanical thermostat the problem could be in there. My bet is a bad connection at display board.
SOURCE: whirlpool upright - freezer part - temp gage on
hi if the temp are ok then you need new sensors or may be pcb .. if you have a standered stat assy change this first as less expensive :)
