Akai LCT2060 Television Logo
billy coulter Posted on Dec 17, 2006
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Initial power-up brand new TV (LCD) 20 in.... 2 wks old. ( AKAI -LCD2016 ) Has been working good for 2 weeks. Now, it shows no red power-light indicator, Also no green light indicator either, although the screen will turn white when I hit the "on" button, then after about one minute, it fades to nothing. Then, when I hit the on-off button, it turns off. ..I'm not getting any picture. I'm using cable TV system. (no dish).. Got a solution? Please help... it's a Christmas gift.
Anonymous
Level 2:
Champion:
  • Expert 367 Answers
  • Posted on Feb 02, 2008
Anonymous
Expert
Level 2:
Champion:
Answers
367
Questions
10
Helped
54629
Points
448
I just got done fixing an Akai LCT2660 that had four bad capacitors on the power board.Works perfect now.Hope this helps.Thank You very much!
Tyler
4helpful
3answers
MY 4YEARS AKAI LCD TV IS BLINKING ORANGE LIGHT BUT
Read the info from the link below to troubleshoot the failure with your LCD. Try not for force the LCD to work because for the time being it might only need the capacitors listed in the link but if the lights is blinking red, then the failure is a bit more complex to repair.
http://www.fixya.com/support/t3771079-lct2701td_t_v_will_not_turn_only
Akai TV troubleshooting
Click here to find the power box for your TV. I would suggest to contact them first with the proper model of your power box before buying it.
PROTRON 26 TWO YEARS OLD
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to [email protected]
2answers
Need Power Supply for Akai LCT3701AD
This post might be of help.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Akai lcd 2oinch tv
Your power supply is bad. This model came with a bad design. Your supply may have a green light on the black box, but it is putting out low voltage or amps. Replace it and you should be good to go.
2answers
Akai tv
The power supply most likely failed on your LCD.
How old is your LCD?
Akai LCT2701TD
I HAD THIS TV AND TOOK IT IN TO BE FIXED AND THEY NO LONGER MAKE THE PART SO I CHUCKED IT. THANK GOD I BPOUGHT A WARRENTY ON THIS TV I ONLY HAD IT FOR A YEAR! NOT A GOOD BRAND
Tv\DVD Wont turn on
Quizas el sistema de la vcr este fuera de tiempo,por causa de la banda del motor de carga el aparato tiene que ser abierto para ser reparado llevalo a un taller.
7helpful
7answers
Akai Plasma TV's screen suddenly went blank -model PDP4294
Same thing for me. TV just turned off one day and won't come back on. LED flashes red. Someone said it's because a cooling fan went out. If I can't find someone to fix it I'll take it apart and tinker myself. 32" with dvd built in was barely over a year old.
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
