Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven that shuts off after it gets to about 380 degrees, bottom oven does same thing. It will then flash and have to turn oven back on. Repeats the same problem over and over. What is problem?
SOURCE: how do you remove the door from a frigidaire gallery series double wall oven(self cleaning)?
Open the door and look at the hinges the connect the oven door to the oven body, on each side you will notice a piece that can be moved back and forth without moving the door, roll each side toward the oven body this should be the locked position, now try to close the door and you will notice the hinges lift up. At this time you need to pull up and push forward on the door and both hinges will come out.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
