Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
Posted on May 22, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Camera dropped in snow
Accidentally dropped in snow, dried it off, took out memory card and battery and dried off with paper towel-shoveled snow for about 1/2 hr./ 45 min and came back to check. Beeps repeatedly when turned to camera on and zoom lens not working. Dried a minute inside battery compartment w/ hair drier and again removed battery and memory card. Ruined battery or camera I wonder? Hopefully it just needs to dry out-would really appreciate any help. This model is actually PowerShot SD400 Digital ELPH-Thank you!
Tony Parsons
Level 3:
  • Canon Master 6,405 Answers
  • Posted on May 22, 2017
Tony Parsons
Canon Master
Level 3:
Answers
6405
Questions
Helped
1652143
Points
20272
Where on earth do you find snow this time of year ? If moisture has got inside the camera, chances are it's ruined, I'm afraid.
2 Related Answers
t00nz
CameraR
  • 4738 Answers
  • Posted on Dec 12, 2009
SOURCE: I have a canon powershot SD400 elph. Camera menu
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Anonymous
  • 341 Answers
  • Posted on May 15, 2011
SOURCE: I have lost my user
Hi you can download from here--
http://www.starbatteries.com/caposd5mpdie.html, open it and click on "Canon Powershot SD400 5MP Digital Elph Camera View the product manual [Download- PDF, "
thanks
Sony Dsc h2o dropped in water
you need to replace the card or dry it out samewhere warm
Dropped nikon coolpix s220 in water took out battery and memory card immediatly is there anything i can do or is it broke
Don't try to turn it on. After drying out the card and battery compartment as best you can, bury the camera in a bowl of dry rice for one week. Then, try to turn it on with your fingers crossed. I'm assuming the water was clear and not saltwater. You still may have a problem with water spots on the inside lens elements if any water got inside them.
2answers
I dropped my lg vu cu920 into the water and it just says emergency dowload, what do i do?
Take the battery out, dry the phone, battery, SIM and/or memory card with paper towels as much as possible. Take all of the pieces and wrap them in a single paper towel loosely. Drop this in a ziplock bag and fill it with baking soda, then zip it up. Let it sit for 2 - 3 days.
The worst thing to do with a phone that has been in contact with water is to run a current through it.
2helpful
My olympus 1040 was dropped in water for a few seconds,i dried it out and now it will turn on but screen is blank,is there anything i can do or is it only fit for the bin..........
Solution: The most important thing to remember if your digital camera should be partially or fully submerged in water is to act quickly. Once your camera is out of the water, avoid the urge to turn the camera on to see if it works and instead remove the batteries immediately to prevent shorting any of the internal electrical components. Remove your memory card also, otherwise you may lose the pictures you’ve already taken and saved to the card.
Leaving the battery and memory card compartments open, dab away any excess water with a dry cloth or paper towel. Then, use a household hairdryer set to the lowest heat or no-heat setting and blow dry the camera for 10 to 15 minutes.
Although the outside of the camera may be dry, it’s what’s on the inside that counts. If any moisture is left within the camera, it may, over time, grow mold, which can interfere with the camera’s operation. If the camera was dropped into a chlorinated swimming pool or a saltwater lake, your camera’s components may suffer corrosion over time, and your camera will eventually stop working.
To help draw moisture out of the camera, pack your camera in a bowl filled with silica gel (the packets of small transparent beads often found in various foods, electronics, and clothing packages) or uncooked rice. Both materials can absorb and hold excess water that may be left in your camera. Leave your camera to dry for at least 24 to 48 hours. Once you are certain that your camera has completely dried out, insert fully charged batteries and press the Power button. With any luck, your camera will function properly. If not, you may try contacting a camera repair company to ask advice or inquire about repair options.
My daughter has the fuji finepix that is white with pink polka dots. she took it to the beach and it was wrapped up in a towel, the tide came in and got the towels a little wet but not soaking wet, she...
you did good and removing the battery and memory card was also a good idea....leave the unit for a couple days the way it is...check later to see if there is any white or green residue(powder) or rust looking areas around the memory card and battery location...if it seems clear then it should be fine, if you see any type residue, then water got into the unit and is starting to corrode it...which means 2 things...either buy a new one or you can still try to salvage this one by having it opened and cleaned out with acetone and dried up completely..then for sure it will be good to go..but first try what I suggested
1helpful
Dropped in water, won't turn on
Was the camera on at the time it fell in the water?
How do I recover the pictures I took fro my canon digital camera. I accidentally press teh format and I lost all the pictures I took. I haven't saved it yet.
firstly don't use the card.
you will need a card reader for your computer
There are many programs that can help you recover faulty formatted or corrupt memory cards. Do a search on google and try a few as some are better than others and some work better in certain situations than others.
searches to try
memory card recovery
memory card repair
Corrupted Memory Card
I wish you the very best of luck..
If I can be of further help drop me a line
1helpful
Frozen Camera
Try letting it drop about 4 tto 6 inches on a hard service covered by a paper towel. Don't let it land on lens of course. You can remove the mem card. It has 13Meg of internal.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
