SOURCE: need repair manual for briggs
After a very extensive cross reference session your engine is model number
10H902-0285-E1 (not provided by you so it took a while)
Your engine is covered in this repair manual:
http://www.mymowerparts.com/pdf/Briggs_&_Stratton_Service_and_Repair_Manuals_Spec_Charts/270962%20Single%20Cylinder%20L-Head%20BRIGGS%20&%20STRATTON.pdf
If there is a problem that your having I can help you if you would just elaborate. I could save you lots of time. The 2 most common failures of this engine is on the carburetor. The parts that fail are the diaphragm (Item 394) and the primer bulb (Item 976) of this link:
http://www.partstree.com/parts/?lc=briggs_and_stratton&mn=10H902-0285-E1&dn=57160004
Carb data is in section 3 of the first link.
Thanks for choosing FixYa,
Kelly.
SOURCE: Briggs and Stratton Governor Linkage problem
The easiest thing for you to do is look at any 12.5-19hp Briggs single cylinder engine that's on just about any riding mower.. They all have the same set-up.
SOURCE: want a repair manual for a 17 hp briggs &
A range of strip-down manuals for all Briggs & Stratton engines is avalable - I got mine from Amazon, but you can get them directly from Briggs & Stratton via their web site. They have a look-up system by model series, which ensures you end up with the manual that covers your engine.
SOURCE: I need a wiring diagram for a 28N777-1194-E1
http://www.briggsandstratton.com/maint_repair/manual_and_more/docsearch.aspx?enginelookfor=28N777-1194-E1
There you go manuals diagrams the lot.
http://www.tulsaenginewarehouse.com/drawings/
http://www.tulsaenginewarehouse.com/drawings/allwiring.pdf
ALL wiring B&S engines above..
Testimonial: "Thanks for the links. Just exactly what I was looking for."
SOURCE: wanted briggs and stratton 92908 manual
Find the B&S website and you should be able to download a parts or service manual.
Think it is briggsandstratton.com.
You will also need your type number (after the 92908).
