When you turn the tv on, it appears to go through the normal startup routine except for some whistling sounds that go on intermittently followed by shutdown of the set.The first time this occurred, the set operated normally after the third try. Last night after several attempts to turn on the set, the screen remained black, however there was sound.
SOURCE: I have a mitsubishi 1080p
i think voltage not get in to ur video board..check that..
thanks for using fixya
SOURCE: RCA D52W20 HDTV TRIES TO TURN ON 3 TIMES BUT WONT POWER UP
It cant be temperature .
I think you need to have a check over the inlet power supply to tv .
Chance of fuse being damaged .
How old is your tv ?
SOURCE: I have Mitsubishi WD-62525. Last
that is a common problem with that model you will need the v26 power pwb repair kit and the V26 FMT pwb repair kit. You can get both kits at the following link which includes the replacement capacitors and instructions on where the capacitors are located. Heres the link.
http://servicemanuals.vstore.ca/
SOURCE: WD-52631 Red Light-No Picture, still have Sound
unplug it from the wall, wait 30 seconds, then plug it back in. i had the same problem and this simple solution worked for me. Good Luck!!!!
SOURCE: Hello there, I have the
If the lamp light blinks yellow, then the first thing I would check would be the filament of the lamp. It is not completely blown into shrads, but it sounds like the filaments is fried. Please check it and let me know.
Sai.
