Check your disk if your files are hidden. Some virus turns folder and files attribute Hidden.To check START>RUN>CMD then go to your disk's drive letter. (e.g. E:) type E: (enter) then type dir/ah.
Testimonial: "Thank you so much I can see my files now in the command prompt will i be able to see them in the windows explorer..? let me see...? no i can't but i can see them from the RUN command. how to I get them back to where I can access them?"
Go to Command Prompt then to your drive. type ATTRIB -S -H -R /S /D
this will make hidden files appears. -S (clear system file attribute) -H (clears hidden file attrib) -R (clear read only attrb) /S /D (applies to folders and sub folders.) :)
Hi thanks for sharing this command, but i need more help. I have the same problem with previous questioner but after run the command above, i got massenge access denied - G:\$RECYCLE.BIN\S-1-5-21-..more number. Can you help me to solve this issue. Henri
