Yes Husky 36 Chainsaw
SOURCE: need fuel mix ratio & plug gap 4 husky 154 sg
Hi there, No problem.
Recommended fuel mix ration if using Husqvarna brand premium Two-Stroke Oil is 50:1. If using another two-stroke air cooled engine oil, you should use 25:1 fuel:oil ratio.
Regading the spark plug, the recommended plug is a Champion RCJ7Y with a plug gap of 0.5mm (or 0.020 inches).
SOURCE: Husqvarna 55 chainsaw won't stay running.
It has a crack in the fuel line between the body and the tank. The crack lets air in the line. Replace the line.
SOURCE: Husky 345 chainsaw will only run with choke almost
turn both carb adj. screws out 1 1/2 turns from bottom and then fine tune them with it running. the one marked L is for low speed and the one marked H is for high speed. hope this helps
SOURCE: Husqvarna chainsaw 440e - enough chain lube?
That seems low to me. Page 15 in your manual is the only oil discussion I found. Usually there is an oil pump adjustment reference somewhere. I didn't see one beyond return it for service on page 15. Are the chain and bar hot after cutting a while? I recommend you not get a longer bar without an oiler adjustment. I think the hand of the EPA has been here.
An IPL (exploded parts list) for a 440 can be found here:
http://weborder.husqvarna.com/order_static/doc/USA/2009/I09000/I0901018.pdf
There is no oiler adjuster listed. HTH
Lou
Might be a good idea to copy the IPL,
Testimonial: "thanking you"
SOURCE: what is fuel oil mix for the 136
Page 8 of your manual says 40:1 (3.2oz/1gal) Stihl or Husqvarna 2 cycle oil.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Fuel/Oil Mixture
Lou
