When the icemaker attempts to refill the cube maker with water it just runs into the cube collector or down into the freezer and also down into the door dispenser. Something is leaking.
You're ice maker is located on the left hand side of the freezer, if I'm correct.
Look to the back of the freezer slightly above the ice maker and you will see what they call the fill tube. Chances are ice has formed inside and when the ice maker goes to fill water sprays instead of flows out. In some models you can take the fill tube out from the back by removing two screws that hold it in, located at the upper right side if your behind it, and some you may have to pull out from inside.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Testimonial: "This helped me greatly. I thought that rather than remove the water tube or icemaker I would simply try to melt the ice blockage. I accomplished this by filling a sport top water bottle with hot water and then dripping/squirting the hot water over the tube and where it entered the rear of the icemaker. It worked. 5 days now since I did this and the leaking has not reoccurred and the icemaker is working just fine."
SOURCE: Ice Dispenser clogged with frozen ice
I have the same problem. Found this posting:
http://www.applianceblog.com/mainforums/sears-kenmore/10491-kenmore-ice-maker-dispenser-door-shute-clogging-missing-heating-element.html
Maybe our heater is not working?
SOURCE: Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
SOURCE: Ice maker not working
Good day,
There are more than one reason for your problem. If the freezer is at normal temperature then use the following. It will pin point the problem.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
SOURCE: not getting water to icemaker;Water dispenser on
3 steps: #1, check the fill tube for ice blockage,If not blocked- #2, verify there is power applied to the water valve when the IM cycles. #3 If yes replace the valve, If no replace switch in IM(complete faceplate in some models). Limited possibilities so elimination of what is working will locate the failure.
Eric
SOURCE: Freezer door is leaking water at the bottom of the door
This sounds like the defrost drain on the freezer side is stopped up causing the drain to freeze over then eventually running out on the floor during the defrost cycle.
If you can see ice on the bottom of the freezer floor, then this is likely your problem unless your ice maker is leaking from the top of the freezer.
Locate the drain at the back of the freezer and thaw it out using hot water. Using a screw driver or other object gently push down into the defrost hole and dislodge whatever is stuck there.
An air hose with good air pressure may also work well. When the drain line is clear you should be able to pour water through it freely.
please provide a model number for the refrigerator.
The refridge model is Kenmore 253.57388600. The Icemaker is a JSI-26.
