SOURCE: Lampcover brightining
Hi there
Your Projector needs a new lamp and do remember to reset the lamp timer after replacing the lamp .
SOURCE: Sony VPL-CS1 projector
Hi there
You should first check if there is any visible damage on your lamp. If not then it could be a faulty Ballast ( lamp powersupply )
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
According to the manual, you need access to the RESET button, the left and right arrows and the ENTER button to clear the counter. Press the following in order for less than 5 seconds each:
RESET
Left Arror
Right Arrow
ENTER
The above sequence should clear the counter.
Dan
SOURCE: Sony Projector VPL-VW 10HT 2 problems 1)The
there is a lock on the projector that needs to be removed. check the manual for the code.
SOURCE: my Sony VPL-ES3 lamp/cover is blinking. Please
Bulb has gone. And wil cost about £200 to replace, could be time for a new projector
