Televison & Video Logo
joe lopez Posted on May 06, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My samsung hl61a750a1fxza only has blue and green picture only, why?
When I turned on my tv, it only has a greenish/bluish tint to it,
RSole
Level 3:
Master:
  • Master 697 Answers
  • Posted on May 07, 2012
RSole
Master
Level 3:
Master:
Answers
697
Questions
Helped
170937
Points
1886
Your red tube is dead. There are three primary color tubes that create all the colors. A new tube can cost $250 plus installation and then you will have an old, obsolete TV with one new tube. A new 46 inch TV is less than $400 these days.
5 Related Answers
Anonymous
  • Posted on Nov 09, 2007
SOURCE: Sony KDF60-WF655 Picture has a blue tint
Sony has decided to cover this cost even without warranty.
Anonymous
  • 121 Answers
  • Posted on Apr 23, 2008
SOURCE: samsung big screen tv model pcl542r has a green or red tint to picture
do you have a service manual for this tv because it may be your red drive circuit and you need to trouble shoot it if you don't have a service manual for your tv I will post a link where you can get one plus free online tech support to help you troubleshoot this problem
http://servicemanuals.vstore.ca/
Anonymous
  • 108 Answers
  • Posted on Jan 09, 2009
SOURCE: Sony Wega 50" DLP bluish tint
the issue is the optical block. replace the optical block
Anonymous
  • 336 Answers
  • Posted on Sep 30, 2009
SOURCE: While watching tv a moment ago the screen began to
Hi,do you hear buzzing,whirling or high pitch sounds? if you do it could be an issue with the color wheel If the TV have the infamous blinking lights problem and you're replaced your lamp without success, it's most likely a problem with your color wheel. The Samsung color wheels spin anywhere from 6,000 to 15,000 revolutions per minute (RPM’s)--It is one of the few consumable parts in your Samsung TV. The average life expectancy from our data logging shows the Samsung color wheels are fairly reliable with a MEAN average of 5-8 years .It could also be the DMD board this is how it works:http://electronics.howstuffworks.com/dlp1.htm One simple way to test if it is the DMD board it's to display thew menu,if menu is also affected that for sure what it is.God bless you!
Anonymous
  • 541 Answers
  • Posted on Oct 29, 2009
SOURCE: BLUE TINT ON MY SCREEN
Philips tv's have always had this problem. Between the picture tube and focus lens there is a layer of coolant fluid. The coolant fluid, over time, will break down and turn a brownish cloudy color and it usually starts with the blue. Something to do with the color frequency. Have a good repair shop check it out and if the fluid is the problem have them change all the fluid in all 3 picture tubes (there is a red, green and blue tube). Don't feel bad, like I said all the philips projo's had this problem. Thanks
Why is my picture green and a loud humming noise?
If the component cables are to connect your television and they are not correctly connected, this can cause a greenish colour picture to occur on the screen of the TV . A high colour tint setting will generally create a green image on the TV's screen where as a low tint will create a more red hue then. The buzzing could be coming from the cables not being properly connected to the TV.
Samsung DLP tv white color turned to yellow
go into menu reset picture settings to default
red , tint or gamma is off
What causes a blue/green screen on samsung dlp TV?
The color wheel is acting up. It may need cleaning. Use extreme caution when cleaning the wheel. Never use paper like a kleenex or paper towel. This will ruin the surface of the wheel. It's best left to a pro.
I have a samsung hl61a750a1fxza model tv and the screen went black. i turned the tv on & off & the color of the picture is now a blue-green?
sounds like the converence is out, and that is why it is shuttin g down on you, and it is going to run around 350 to get repair. ConvergenceICs' needs replaced.
I have a Sony kv-27fs100. It has a greenish tint/patch along the left side and a bluish patch along the right side. Any ideas?
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Blue Picture
blue crt is bad and sorry to say not avail new any more
2answers
Blue tint on rear projection tv
If this is a crts model , then one of the crts had blown, if it is a lamp rear projection, then it is a fault on the video circuit.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
