Cylinder won't fire
Every internal combustion engine needs compression, fuel, air and spark. If any of these are missing, the engine will misfire. Lack of compression can be due to head gasket failure, burnt valves or worn compression rings. Rings are the most unlikely if only one cylinder is misfiring. Lack of compression can be measured with a fairly inexpensive pressure gauge from the local auto parts shop. The cause of lack of compression (head gasket, burnt valves) will be a more serious matter.
Compression is measured by removing the spark plug of the suspected misfiring cylinder and inserting the pressure gauge firmly into the plug opening while an assistant (your wife or sweetheart will do fine) turns the key to swing the engine. Compare the reading with a known good cylinder. The readings should have at most not more than a 5% variance.
If the compression is good, start with the spark. Do not be fooled by a "nice"spark coming from the plug lead. Swap plug wires with a known good cylinder and see if the problem moves. Check the distributor cap for cracks, which also are sometimes next to impossible to see with the naked eye, so if an exchange cap is available, try swapping. The final, but most unlikely culprit is the spark plug itself. If it is not new, fit new plugs, they\'re cheap enough.
Then, a sly little monster that has caught me a time or two is the distributor cam. In an older vehicle the distributor cam can have a worn bush, which will open the points when the cam is on one end of its travel, while barely or not at all open the points when it is opposite, thereby causing a weak or even absent spark to the cylinder it is supposed to ignite at that end.
Since the other cylinders appear to be firing OK, the problem is not with air supply (unless of course the air intake inside the manifold is blocked by a rag someone had forgotten to take out while they were cleaning the engine, but let\'s not go there.)
