Question about Pool & Spa
Overheating New pump clicked off due to overheating. Solution?
  • Pool & Spa Master
  • 1,389 Answers
YOU MIGHT HAVE SET THE VOLTAGE WRONG.. IS THE MAIN BREAKER WIDE OR NARROW ? IF THE BREAKER THAT RUNS THIS PUMP MOTOR IS NARROW YOU NEED TO SET THE MOTOR FOR LOW VOLTAGE 115V ON THE MOTOR LABEL THERE IS A DIAGRAM ON HOW TO SET IT.. YOU NEED TO GIVE MORE INFO LIKE PUMP MANUFACTURE, TYPE AND MOTOR SIZE HP AND SF SERVICE FACTOR..WELCOME TO MY WORLD !
.JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA.. REMEMBER TO VOTE FOR YOUR FAVORITE FIXYA GUY
Posted on May 08, 2012
6ya staff
SOURCE:
Coolant blowing out of radiator after 20-25 minutes.
definitely sounds like an overheating problem most likely due to an air bubble blockage. needs to be bled properly.
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
Apr 03, 2016 | Cars & Trucks
Xr250 engine seized
Hi, Anonymous you may have hydraulic lock caused by excessive liquid in the cylinder or you have squeaked your top end this is commonly known as "HEAT SEIZE" the piston heats up expands and becomes extremely tight in the cylinder bore and usually occurs mainly on 2 cycle engines right after a fresh top end rebuild, but it can also happen to brand new motorcycles, these are rare instances due to better quality control and education. Overheating failures that cause pistons to seize are many and each one should be carefully diagnosed to prevent future repeat offenders and the usual suspects are:
1. Lack of lubrication due to low or no oil.
2. Among the causes of lack of cylinder, lubrication is clogging of lubricator by dirt or waste, obstruction in oil pipes/lines, leaky check valves, leaky pump packing, broken oil pipe/line, oil too cold to feed.
3. Wrong type of oil used in premix or oil tank.
4. Improper premix ratio you should start with 32:1 as a baseline.
5. New rebuild piston to cylinder tolerances set up too tight.
6. Failure to follow proper break in procedures with a 16:1 premix ratio.
7. Loose fasteners causing intake, base, or head gaskets to leak or blown crankshaft seal, failure caused by age, overheating or walking. 8. Holes in the intake manifold bent or warped intake flange or reed cage any stray air coming into a cylinder will cause a super lean condition.
9. Improper assembly of reed valve gaskets.
10. Insufficient warm up time for temperature conditions before wide open throttle.
11. Broken, pinched or cracked fuel line.
12. Carburetor fuel passages clogged or restricted from stale fuel varnish, ethanol sludge, dirt, rust, or fuel level in float bowl too low.
13. Main jet size too small or partially clogged
14. Air filter improperly installed, missing or not sealing.
15. Faulty or improperly adjusted oil pump and or cable.
16. Failure to bleed oil pump after a rebuild/replacement or running oil tank dry.
17. Engine coolant level too low, too old, or improper mixture ratio.
18. Radiator clogged, fins damaged, or faulty cap.
19. No liquid circulation due to failed oil or water pump.
20. Cavitation due to air in oil or coolant system.
21. Water and oil mix due to blown head gasket.
22. Timing retarded due to faulty CKP sensor or CDI.
23. Improper spark plug heat range (too hot) and or gap.
24. Excessive engine load, brakes dragging, clutch slipping, transmission lubricant level too low or viscosity to high.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
xr250 possible seized engine
Honda XR250 seized advice
Honda XR250R Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda XR250R Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 01, 2014 | 1998 Honda XR 250 R
Yz 85 head jam
10. Insufficient warm up time for temperature conditions before WOT.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Dirt Rider Magazine
Unsticking Stuck Engines
http://www.motogelnar.cz/manual/YAMAHA/YZ85_05.pdf
OEM parts for Yamaha
YAMAHA YZ85 Owner Manual
Dec 07, 2013 | 2005 Yamaha yZ 85
1977 Honda GL 1000 overheating
Hi, Anonymous and the usual suspects are:
1. Engine oil level and SAE weight are too low or not circulating.
2. Insufficient or blocked airflow over the engine.
3. Heavy combustion chamber carbon deposits.
4. Ignition timing retarded due to a faulty MAP, CKP, or CMP sensor.
5. Carburetor jetted too lean.
6. Leaking intake or exhaust valve.
7. Clutch slipping, brakes dragging, heavy load, towing a trailer.
8. Idling too long without moving.
9. Constant hot weather temperatures, mountain, or desert riding conditions consider adding an oil cooler and or cylinder head cooler.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
77 gl1000 overheating problem GL1000 Information Questions goldwingdocs com
Overheating
Honda GL 1000 Shop Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda GL1000 Owner Manual
Jun 29, 2012 | 1977 Honda GL 1000 (K2)
My well water pump is short-cycling & shuts off due to overheating. Any ideas??
If it is short cycling the tank is probably water logged and needs to have the empty air level set. Basically that means drain the tank (pump off first of course) then check the air in the bladder. Should be a couple pounds less than the low cut in setting of the pumps pressure switch. This should let the pump rest between cycles and stop the overheating. If it still overheats you have a failing pump and will need to replace it or rebuild it.
Jun 28, 2012 | Plumbing
Overheating
Did you try changing the ran relay under the passenger's headlight?
Mar 15, 2010 | 2001 Jeep Grand Cherokee
Overheating 2001 chevy impala
Believe it or not, new thermostats can be bad. Did you maybe get some adhesive on the thermostat preventing it to open fully? Is the thermostat installed with the crown up? The only other thing that I can think of, if it's a closed cooling system and the wrong radiator cap is installed, it won't hold the pressure, therefor overheating. The other thing may be the water pump. Many times the impellers will wear down internally causing to low of water flow.
Jul 16, 2017 | 2001 Chevrolet Impala
Starts then dies..
heat is a big factor in the distributor module!
they beak down [no current ]
resulting in no plugs firing & can be intermitant also
Jul 20, 2009 | 1994 Chevrolet K1500
Overheating
you might have a blown head casket try due a pressure test on each cylinder and sometimes you can take a spark plug out 1 by 1 and just tap the ket so it cranks and see if water comes out of the cylinder
May 20, 2009 | 1995 BMW 5 Series
Overheating
If the car is overheating it could be due to a thermostat which is stuck in the closed position, a failed water pump or just a slack belt driving it. I think there will be a "little" tube carrying coolant from the engine to the coolant expansion tank, and if you run the engine with the filler cap removed you should see water coming through that pipe IF the rump is running. A failed water pump will not necessarily leak, it just won't pump the water round the engine.
Always take care when dealing with a pressurised cooling system on an overheating engine - the water may well be above boiling point.
If you run the engine without coolant the cylinder head may well warp and repair bill will be huge.
Hope this helps you a bit. D
Jul 19, 2008 | 2003 Volkswagen New Beetle Convertible
Pool & Spa Logo
94 people viewed this question
Top Pool & Spa Experts
Bill Jordan
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
