Showing green dots on screen, adjust colors still see them bought this tv on 2006 62 inches, never had any problems with it or bulb replace yet.
Not sure if it has any warranty still, need to check on that , any help will be appreciated..
SOURCE: mitsubishi rear projection tv color problem
I'm going to guess that this unit is a DLP projection set and that the lamp is not new. Try a new lamp. The heat of the lamp will char over time. If not the lamp, some of the internal filters in the light engine might be getting effected by heat and require replacement.
Keep us posted.
Dan
if the light just constantly blicks green and doesnt stop. You will need the" V26 DM repair kit " which will usually repair that issue. You can get the repair kit at the following link which includes the replacement capacitor and instructions
http://servicemanuals.vstore.ca/
SOURCE: mitsubishi 62 inch microdisplay hdtv w/screen w/zy
I have a list of problems common to this series here:
Cause #1
1. (Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for
12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check
for an open F9A09 on the Power PCB, if it is open replace F9A09 part #
283P127060 and the Light Engine part # 939P977010 3. (Lamp may light and go out)
Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if
low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the
Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three
times and then the unit shuts down with a red lamp LED (lamp error). Replace the
Light Engine part # 939P977010 5. Lamp enable line at J14 pin 6 does not switch
to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light
Engine part # 939P977010 6. Lamp enable line at connector J14 pin 6 on the
Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low)
after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB
(ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the
Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-
volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light
I would start with #3, checking the 5 volt line and replacing the listed capacitors if needed.
Please be sure to rate this solution. Thanks!
I've got same problem, now six small green dots on right half of screen (number has been growing), with 65" DLP rear projection Mitsubishi HDTV. How to fix?
