And how is one to replace the key pad? Can we buy the part and do it ourselves? and Is it expensive?And how is one to replace the key pad? Can we buy the part and do it ourselves? and Is it expensive?
You can't post conmments that contain an email address.
Check those 3 micro switches in the door latch assembly. The unit will not start until all interlock conditions are met. Could it be the keypad membrane, yes. Is that likely, no.
You may have a failed keypad or moisture or grease on the keypad innards or on the control circuit board itself. You can find a video here that shows you how to remove the grille & controller in about 5 minutes if it's an over the range model. You can order Panasonic parts from
Encompass here
http://tinyurl.com/7qy85y or you can call them toll-free at
866-779-5835.
The keypad very well could be worn from use and be working intermittently. Replacing the keypad (and the keypad face if it is a separate piece) is the most logical solution.
Yes you can use a hair dryer but the power should be off so that you don't short it out any more than it already is. Most likely the keypad has been ruined and will need replaced., Once these go bad there is no fix except to replace the keypad.
If you;re not from the US or Canada, consult your owner's manual or the dealer you purchased it from to contact Danby to find find your nearest Danby servicer.
You need to replace the touch pad assy. Moisture gets up around the contacts and, it doesn't take much to short them out. Some will work, others will not. Eventually, others will fail, leaving it inoperable. Recommend fixing ASAP
