SOURCE: DELL 1720 PRINTER PRINTS VERY SLOWLY.
Whenever I have a customer tell me their printer seems to be running slower, 9 times out of 10 its what they're trying to print...not the printer. Heres a couple of things to do and ask yourself. First I'd do a test print from the printer itself. Does it kick it right out? Then go to the printer folder on the computer, right click on the printer, go to properties..click print test page. Does that come out pretty quick? Okay if they seem relatively fast then its beginning to look like something other than the printer. Try printing the job that seems to run slow. Then try printing from a different program. Is there a difference in speed? The job that prints slow may have graphics or require more memory then it use to. Perhaps you changed the graphics content on the page and the printerr is taking more time to process it. Adding more memory to the printer can help that.
Did you make any software change to the printer about the same time you noticed the slow down?
Have you changed the font color in the computer to something other than black for that particular print job? I've seen monochrome (black and white) laser printers slow down because its trying to convert the job to say violet or some other color. Its a black text printer and apparently printing color confuses it ..lol My bet is..if you really sit down and think back...something changed in the content of what your printing thats taking it longer to process it. Hope this helps!
SOURCE: Problem with Dell 1720 printer
Hello
You have to check couple things in this case.
Ensure that the printer cover is closed.
Repeat
this procedure multiple times until the print remains faded. When the
print remains faded, replace the toner cartridge.
or
The imaging drum is approaching full and needs to be replaced. Order a
new imaging drum.
