There is a short in the wiring were the hinge is at. You can take into a camera store or Best Buy and see what it would cost to replace the wiring in there.
Did you try pressing the display button several times? in both viewing mode and record mode? Cycle through all display modes, s you get used to the button, so it does not trow you off when it happens again.
Apparently the vendor-supplied CCD image sensor used in this Canon digital camera may cause the following malfunction: When the product is used in recording or playback mode, the LCD screen and/or electronic viewfinder may exhibit either a distorted image or no image at all.
To determine if the CCD (image sensor) is working properly, follow these steps:
1. Insert a memory card with known good images on it into the camera.
2. Power the camera on to the Playback mode.
3. Press the DISPLAY (DISP) button to enable the LCD panel, and observe
the LCD.
a. If the images are displayed properly, please proceed to step
four.
b. If the images are not displayed, or a "NO IMAGES" message
appears, please ensure that the memory card contains known good images.
c. If the card contains known good images, and the issue persists
with a second memory card, the camera will require service.
4. Switch the camera to the Camera mode. You may use any shooting mode
(i.e. Auto, Manual).
5. Press the DISPLAY (DISP) button to enable the LCD panel.
6. Point the camera at a well-lit scene and observe the LCD and/or
viewfinder. If the scene the camera is pointed at appears on the LCD
and/or viewfinder, the CCD is operating properly. If the LCD and/or
viewfinder remain black, the camera requires service.
Effective immediately, and regardless of warranty status, Canon will
repair, free of charge, products exhibiting the above-mentioned
malfunction if the malfunction is caused by the CCD image sensor. Canon will also cover the cost of shipping and handling in connection with this repair.
Based on the information you have provided, it appears that you may have encountered this issue. To determine if the CCD (image sensor) is working properly, please follow these steps:
3. Press the DISPLAY (DISP) button to enable the LCD panel, and observe the LCD.
a. If the images are displayed properly, please proceed to step four.
b. If the images are not displayed, or a "NO IMAGES" message appears, please ensure that the memory card contains known good images.
c. If the card contains known good images, and the issue persists with a second memory card, the camera will require service.
4. Switch the camera to the Camera mode. You may use any shooting mode (i.e. Auto, Manual).
6. Point the camera at a well-lit scene and observe the LCD and/or viewfinder. If the scene the camera is pointed at appears on the LCD and/or viewfinder, the CCD is operating properly. If the LCD and/or viewfinder remain black, the camera requires service
This sounds like CCD sensor problem ( especially if the picture is "noisy" ). Canon and Sony fixes this particular problem free of charge since the CCD device installed in your camera should last + - 15 years if it is properly manufactured. Contact your agent and find out what their policy is.
it is same with my camera same type also.the problem is from flexible cable from mainboard to lcd .same of the core is break..until now i can'ot get that cable.
you just buy the cable and on your camera and ok.
if you have information abaut that cable please submit to me
If the LCD display is open, the viewfinder becomes inactive. Shut the LCD
display, and the image should appear through the viewfinder.
If there is still no image, the camcorder may require service.
