Cameras Logo
Posted on May 04, 2012
My Kodak easyshare m530 just stopped working. When I go to switch it on the screen flickers and there is a vibrating noise, the lens is all the way out and stays like this all the time, please help, thanks.
5 Related Answers
camerac613
  • Posted on Jun 15, 2008
SOURCE: Lens stuck open
I have a Kodak C613, it was dropped down the stairs and the lens in stuck out, and will not come in. When I turn it on it says "Lens Error: 123, 0, 0, -23" It fixed itself once, but now it will only let me view picture when I go to favorites mode before I turn it on, then press review. Any ideas on how to fix it?
A
Anonymous
  • Posted on Aug 28, 2008
SOURCE: Kodak EasyShare Z710 - Lens won't retract or close
My Z710 does the same thing. is dead wont turn on. I sharp hit with the palm of my hand and it turns on everytime!
Anonymous
  • 62 Answers
  • Posted on May 01, 2009
SOURCE: lens won't come out (Kodak EasyShare C613)
i have the exact same camera
you can hang it up and get ready to buy a new one because its not a do it yourself job and it would cost more to have it fixed than it would to buy another one just like it
Anonymous
  • 11967 Answers
  • Posted on Jun 22, 2010
SOURCE: Kodak Easyshare M320 Memory Card Protected
If there is a slide switch on the side of the card, make sure it is "unlocked".
Anonymous
  • Posted on Nov 24, 2010
SOURCE: I dropped my Kodak EasyShare
I have this same problem, but I never dropped the camera. I got it 2 months ago.
The flash works when switch on then stops
Sounds like faulty flash capacitor, This is not a user fix, needs to go to shop.
I dropped my Kodak Easyshare M530
you would have to take the camera apart and probably replace the the screen or reattach the cables for a better connection.
My Kodak EasyShare M530 will not turn on, and it is making buzzing noises when I try to turn it on.
its a lens jammed issue. Noise came from lens area. Use air on the lens area for cleaning the dust and then try. If required then trust it in other hand little bit. Not too harder.
My kodak easyshare m530 digital camera can't Autofocus
The lens needs to be taken apart cleaned and lubricated, overtime they build up dirt and grime causing the gears to become stiff, the only solution is dismantle the lens and clean it until spotless. If a camera specialtist gets in involved it will be expensive.
If I try to turn on my kodak easyshare m530 it turns on and the lens comes out then a few seconds later it turns off and the lens is still out and its fully charged. Can anyone help me solve this problem?
Sounds like a lens error problem. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Can i get a manual for the kodak easyshare m532
user guide:
http://support.en.kodak.com/app/answers/detail/a_id/19260/kw/m530
extended user guide:
http://support.en.kodak.com/app/answers/detail/a_id/19257/kw/m530
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
