My manual is not clear how to attach the darning foot. Help would be appreciated.
on the machine, there is a foot holder attached to the machine, & the feet to the machine will either be snapped on to the foot holder or there is a screw to undo. most of the new machine are snap on feet, take the presser bar lever up, there is a little lever on the back of the foot holder, & you push it toward the foot holder bar & it will release the foot & you put the other foot down on the needle plate & bring the foot holder bar down on the foot until it snaps on to the foot
SOURCE: How to attach Singer Free Motion/Darning Foot to Singer 7442 machine?
To learn the skills to repair sewing machine by yourself, I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional step-by-step repair guide written by an expert. Besides Singer sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
SOURCE: what free motion foot can you attach to this singer 3116 model?
This low shank foot will work on that machine. Singer 3116
sewman7
SOURCE: Pfaff quilt expressions 4.0 shows
A lot of these Ex 4.0 have defective cutter motors. The arm that the cutter is attached to passes by a sensor that tells the machine when the cutter is at the rest position. And what is happening is that the arm is no longer in place to tell the sensor where it is, and it stops short of the rest position. This part is covered by PFAFF for a 5 year period. You'll just have to have a PFAFF dealer install it and pay a labor charge.
SOURCE: Someone gave me a Life
I would suggest you contact Pfaff firstly to see if you can obtain a manual, its always worth having the one for your machine. I presume you are in the USA? if yes, go to www.pfaffusa.com or ring toll free 1-800-446-2333 Monday-Friday 8:00a - 4:00p CST or email [email protected]
or go to www.pfaff.com then choose your own country then go to "contact us". and find the details.
Using a rolled hem foot is the same on all sewing machines, you are introducing the cut edge of the fabric into the front of the foot and it rolls the cut edge twice, as you seam over it. Its fiddly, you need a straight trimmed edge, and you have to keep the same amount going into the foot for it to work. You can either straight stitch or do a small zigzag over the fabric. Getting it started is the hardest bit because you need something through the foot to stitch on so it doesn't just get pulled into the hole on the needle plate.
try this link http://sewing.about.com/library/sewnews/library/aatech0803.htm for a bit more info on this, some machine makes sell a 2mm, 4mm or 6mm foot for different weights of fabric and finishes. You can buy accessories for your pfaff from www.sewingpartsonline.com or from Pfaff. Pfaff website even has free projects and a newsletter for customers.
Just put the foot on, lower the pressure foot onto the edge of the fabric, do a couple of straight stitches, then raise the pressure foot and pull the fabric back an inch, so you have something to hang onto at the back, then put 1/4 of fabric into the open part of the foot, hold it there, lower the pressure foot and start stitching, keep a bit of fabric turned in in front of the foot so you help it go into the foot and try to keep it a constant width, trial and error, you'll soon get the hang of it.
Piping can often be done with your zipper foot, you just want to encase the piping cord with a bias cut fabric strip and stitch as close to the edge of the cord as you can to hold it nice and tight. Then put the piping strip between two pieces of fabric and again stitch close to the cord so the first line of stitching doesn't show. Some machines, the zipper foot will have a guide so you can squeeze the cord up against the foot. Here is a link for piping techniques http://sewing.about.com/od/techniques/a/covercording.htm and covering cord http://sewing.about.com/od/techniques/ss/cordingpiping.htm
Just cut the bias strip width to suit your cord width, join the bias strips together if you want lots of length, then wrap fabric around the cord, right side out, put it under the zipper foot and stitch through the fabric as close to the cord as you can, on some machines you can adjust the needle position to get close but check your manual for help on this, you don't want to strike the foot, just sew up close to it.
I haven't done double piping, but I presume you would sew two layers of piping on top of each other?
I've got a old "Sewing Soft Furnishings" text book that I found at the op shop for $2, the images are daggy but the techniques don't change, most furnishing stuff is just taking measurements, adding seam allowances, and sewing straight seams, so the machine doesn't have to be fancy, or need lots of accessories, just know-how. What you do need is a strong machine to sew upholstery fabric, many domestic machines just won't handle heavy weight fabrics too well. Large sized needles 110 size will be important too.
I'd suggest you try one of Debbie's free pillow guides as a start http://sewing.about.com/lr/free_pillow_projects/271734/4/ , go for something without a zipper at first, and once you've made a couple of easy pillows, your confidence will grow.
Good luck with your Pfaff and enjoy your sewing.
SOURCE: I need a threading diagram
Good day!!!
Please try to click the links bellow...
http://www.shopwiki.co.uk/pfaff-expressions-model-2034-sewing-threading-diagram/products/pfaff?sb=1
http://www.promanuals.com/serviceparts/pfaff-expression-2034-2044-instruction-manual/
this one bellow is not a 2034 but it is also pfaff I just include this for your much Idea..I hope it helps..
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Pfaff_Sewing_Machine_Threading/Pfaff_145_threading_Diagram.htm
Please Sir let me know if this solution help you or not so that I can find a better sites for you....
Thank you...and good luck...
Thanks for trying to help, but the darning foot doesn't fit the way all the other feet do. However, I went to a dealer and they showed me how to do it. Pfaff need to update their manual to show how to attach this foot.
