The computer switches on, but won't boot. The processor fan can be heard running fast and it will stay in this state for hours.
Simple dear, I think that you can see the power led and hdd led but it wont boot. Right. So switch the system and than open the cabinet and than remove the RAM , CLEAR THE DUST ON THE SLOT AND RAM. THAN REPLUG IT IN THE SAME WAY. PLEASE DO NOT INSERT IT FORCEFULLY BECAUSE IT WILL GO EASILY IF YOU ARE INSERTING IT IN RIGHT WAY. SO CHECK THE POSITON OF THE NOTCH ON BOTH THE RAM AND SLOT OK
AND THAN START THE SYSTEM. THIS MIGHT DEFINATELY SOLVE YOUR PROBLEM.
Check to make sure the Heatsync is fast to the motherboard.
I found one of the 2 sides was grossley loose. No problems after that was done ... also put new heat sync compound on . ( you can find that at your local Radio Shack )
The above solution fixed the problem for approximately 6 reboots - but the problem has occured again - can anybody assist please?
I have a similar problem. I have an E50 Thinkcentre which recently stopped going past the IBM splash screen. The screen reads "checking DMI pool......................." then the screen blanks and nothing appears, despite the fans running.
Can anyone help?
i have a smilar problem with my 600x laptop but little different, when i try to on it the power light come on but it will not pass that stage. and sometime it will boot untill it finally stoped. but its still powering but not booting i dont know if the offered soluti9n can solve my problem but i will try ur option
thanks
I have a similar problem, in that my thinkcentre used to boot up ok, but now both the CD and DVD drive lights come on and the CPU fan is running but it won't boot at all.
