Which is it? PC cant connect or not able to setup wireless? If the router came with a setup CD, run that from your pc... Make sure you have a crossover Cat5(ethernet) cable connected between the router and a PC just to set it up initially... within the router can enable or disable wireless function... But to really narrow your device down, i need to know the hardware revision number... its on the same label as the MAC address on the outside of your router
Your question is Do you need drivers.
You do not need drivers to install it, it should function fine without the drivers.
What exactly is your problem?
Much inrformation and all the answers you have can be found here - http://www.dlink.com.au/Products.aspx?Sec=1&Sub1=2&Sub2=5&PID=62
That should help you.
Access the configuration page of your router by default its 192.168.0.1, Login to the Dlink page by default the Username is Admin and Password is Blank and then reconfigure your router for Internet connection.
There are multiple revisions of the DI-624,
each with version specific drivers, firmware, installation guides, and
other resources. Please use the descriptions below to
identify your revision. The links will take you to the drivers and install guides.
Note: The revision is located on the label on the bottom of the device next to H/W
The DI-624 Rev. A has 2 antennas.
<img src=http://support.dlink.com/prod_img/revisions/DI-624v.jpg>
Yes, you can connect the DI-624 to your exitsing EBR-2310, you just need to connect the a cable from port 4 of the EBR-2310 to the internet/wan port of the DI-624, then after that you can already use now the wireless to your laptop and also the wired router to your desktops.
But I may suggest you to just replace the EBR-2310 with the DI-624 so you will only be using 1 router that can cater your laptop and also your desktop, Just connect the cable from your modem that is conencted now to your EBR-2310 to the internet/wan port of the DI-624 then run the setup CD that should be it.
You don't need any software, no.
All you need to do is login to the router (usually 192.168.2.1 or 192.168.1.1 for D-link) and configure the wireless security (including the key)).
