Error message sound card not found
Hi Good day!! try to re install your sound driver using your cd, or you can download it from here: http://www.dell.com/support/drivers/us/en/19 select your operating system and select audio driver
SOURCE: Thoughts on the Dell Inspiron 580 w Intel Core i5-750 processor
the unit has a good specs. but will still vary in your needs. ask yourself a question. where will i use this unit? is it in games, personal (like for office use). coz if it in personal this is fine. but if in games, need more boost.
SOURCE: dell inspiron 580 does not power up
If you have further questions feel free to reply to this solution. Thank you.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
SOURCE: will all wireless adapter brands and models work
If your talking about a wireless adapter that plugs in via a USB port then yes. If you are talking about a wireless network card that is installed into a PCI slot inside the computer, you can check with the network card manufacture for the specs but it should work as long as it is Windows compatible.
SOURCE: On my Dell Inspiron 580
If it burns other discs just fine and not CD-R discs, I would suggest you try a few diferent brands of discs. That should alleviate your issue. If it doesn't, its probably a good idea if you just replace the drive completely. You have purchase one from a local electronics retailed for around $30.
SOURCE: bought a new dell inspiron
Did you buy speakers? the Dell Inspiron Desktops do not have an Internal speaker, you will need extenral POWERED speakers for audio
