In have a62" toshiba dlp.... i hear sound but no pic.red and green light on flashing...I replaced the lamp...now the same ...no pic...then red light is on and green light flashing..like is trying to turn on...this happens several times...then there is a humming noice..it seems to come from the lamp area???
Was the lamp blown if it was blown you could be hearing the ballast
if the lamp was not blown and the new one did not fix it the red light indicates the door there is a little switch when you put the door back on if you look at it it may need to be adjusted so it will connect with the door if that is not it you could have a fan that is not turn if it is making a real loud constant humming noise while it trying to fire the lamp you probably have a bad color wheel
i replaced the new lamp on my toshiba tv 54HM95 it making noice
i replaced the new lamp on my toshiba tv 54HM95 its working but lamp making noice
toshiba tv 54HM95 i replaced the bulb but humming noice comming what is the problem
toshiba tv 54HM95 i replaced the bulb tv is working but humming noice comming near the bulb what is the problem
