The TeamPad is working, but when i connect it to a PC, through a USB port, it does not get connected. The software am using to connect to the PC is Microsoft Active Sync. Kindly help me in resolving how to connect to the PC and install it and how to share the files between them.
Google translate on Marvel_co's soluton (GoodLuck): you already reviewed the cable usb? usb is front or to rear, you proved to use it in another different one or another equipment? ?. if it works? I could be problems of configuration of the operating system and habria which to reinstalar it, if it is changing usb, front they are generally 1,1 and to rear 2,0, if it even presents/displays problems uses to driver but present the possible thing, not the one that come with the hardware? and if not contact technical support of fabricante.NVV
In spanish.... use translator please ya revisaste el cable usb? el usb es front o rear, probaste usarlo en otro diferente o en otro equipo?.... si funciona... pude ser problemas de configuracion del sistema operativo y habria que reinstalarlo, si es cambiando el usb, generalmente los front son 1.1 y los rear 2.0, si aun presenta problemas usa un driver lo mas actual posible, no el que viene con el hardware... y si no uffff soporte tecnico del fabricante.NVV
Hi there !
I also having same problem as you have ... do you got it to work
Pls email me [email protected] anything you can help....
thank a million..
Trung
