Video Game Consoles & Games Logo
Jason Mabe Posted on May 03, 2012
My ps3 turned off during game play and the light flashed blue green yellow and then kept flashing red and if I wait a long time and try again the fan turns on light god blue for one sec then turn a yellow green then back to flashing red oh yea and the in it won't eject
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on May 03, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
837
Points
6
I'm afraid you have gotten the Yellow Light of Death ( YLOD ) you will need to have your PS3 repaired by a technician or you can Google YLOD and you will find a repair guide.
5 Related Answers
Anonymous
  • 18 Answers
  • Posted on Jul 06, 2009
SOURCE: Yellow Light
You have what is called the "yellow Light of death". It is the ps3 version of the Xbox 360's Red Ring of Death. Use these videos
Anonymous
  • 105 Answers
  • Posted on Aug 03, 2009
SOURCE: having problem with my ps3
Sounds like the PS3 is bricked. Try using the recovery menu, Directions here: http://www.xtremeps3.com/2009/01/28/how-do-i-access-the-playstation-3-recovery-menu/
Anonymous
  • 24 Answers
  • Posted on Nov 20, 2009
SOURCE: ps3 in standby mode nothing else will happen
the red light will stay on allways and your controller is probably charging is why its flashin if u HAVE to turn it all the way off take out tha games and flip the switch in the back
Anonymous
  • 943 Answers
  • Posted on Mar 28, 2010
SOURCE: ps3 dead
you have to take it to a good repair shop.
Anonymous
  • 231 Answers
  • Posted on Jul 03, 2011
SOURCE: What's wrong with the ps3 when you turn it on it
Sounds like an overheating issue to me. Make sure to keep it in a well ventilated area. Also, the next time you turn it on, put your hand near the vents to see if any hot air is being expelled through them. If there is NO air being expelled, you have a bad fan. It may also be that the heatsinks aren't conducting enough heat from the processors...this could be due to bad thermal paste. You may need to send it in for repair for this you can call 1800mysony.
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
I was playing online when suddenly my ps3 switched off, when i tried to switch it on by touching the touch sensor when the indicator was red, it turned green normally as soon as the normal green and blue...
This is a rare problem ............ i faced similar kind of problem
i solved my problem with the help this repair guide you can also try this out i hope this will help you a lot .......
all the best
Click Here
1helpful
Will not power up, red light goes green flashes yellow then stays flashing red
Yellow lights and blinking red lights indicates general hardware failure on ps3. If your ps3 is still under warranty call Sony and they will send you a new or refurbshed one. Your ps3 is one in a billion (according to Sony). North America: 1-800-345-SONY (7669) United Kingdom: 08705 998877
Now you could try doing a few things (hey it's worth a try!)
1. Turn off the switch in the back and wait a few minutes. Turn it back on and try it again. If that doesn't work it may be dead.
2. You could try this article, if you choose to, it's a long shot but might work for you in your case. http://ps3.qj.net/Possible-PS3-flashing-red-light-fix-from-MXACE/pg/49/aid/75721
When I turn on my PS3 the light flashes green 3 times then yellow twice then red. It won't eject the game disk. I've tried holding the eject button for up to 30 seconds without success.
Yellow lights and blinking red lights indicates general hardware failure on ps3. If your ps3 is still under warranty call Sony. North America: 1-800-345-SONY (7669) United Kingdom: 08705 998877
2answers
I was playing oblivion the the game froze for a bit
try this. works for slimline PS2.
1) turn off PS3
2) unplug PS3 and wait a couple minutes before plugging back in.
3) turn on PS3
hope this helps :D
Ps3 wrecked
it has a bug if it is a 40 or 60gb they are the ones that have it.
1helpful
PS3 Green then Yellow flash then blinking red
or you can try to get your money back if you hve a receit i say give it bak and get you a new one. or see if you can find one ebay or game stores
1helpful
PS3 light turns GREEN, w/ blinkin BLUE, to YELLOW, to flashin RED
it is fried and needs repairs if you break the seal by trying it yourself you void the warrany
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
