SOURCE: Problem on Manitowoc Ice Maker Series 150
if the reed switch is not tripped at the end of the harvest cycle it will shut down. when ice drops it hits a cover with a magnet on the right bottom corner. the ice falling moves the magnet away from a switch and lets the sequence reset and start over.
SOURCE: Help! my manitowoc! leaking!
I'm having a little trouble finding that model but if you contact them or can find a better or different number it may help. You can also contact them and order parts or order from one of their suppliers. Here is their link to home page. With the correct model number you can find your service manual and part number. Hope this helps. Manitowoc is pretty good about helping out. Sea Breeze
http://www.manitowocice.com/index.asp
SOURCE: i have a manitowoc commercial
Check to see if the compressor is running... if it is running and not cooling then it may have a refrigerant leak...
If the plate is getting cold but the water is not freezing then check to make sure that the float is not stuck on and the the water just keeps running in... that will keep the water warm enough so that it does not freeze...
heatman101
