That is almost certainly what is happening. I have never needed to vent these into soil stacks, as I have never had a complaint of an odor. There's simply no reason to do it...I would dis-connect it from stack and allow to vent as it was intended. DW
#K4421 Re black specks coming from rim jets (only). Me too. Looks like bits of rotting rubber. Water in tank is clear-no specks there. I suspect the small hose from fill valve to top of flush piston may be breaking down, as it has gone rigid and I'm afraid to squeeze it lest it shatter. First thing I'll try is replacing that hose, if I can find one. My daughter has same toilet but no "specks". With her toilet, it's the same small hose but the problem is it occasionally pops off at fill valve end. I can fix that with wire but when I find hose source, I'll buy two.
It could be a bad seat around the flapper or the flapper itself. Replace flapper with one designed for the Cadet. Check water level and see it doesn't flow above the overflow tube. if it is above the tube lower the float ball by turning the screw at top of ball.
either
the fill valve is running and water is draining into the bowl via
the overflow tube in the tank or the flapper is bad (or foreign matter)
and it is allowing water to escape into the bowl through the flush valve slowly...causing the
tank to drain and the fill valve to run every few minutes or so. start by inspecting/cleaning or replacing the flapper and hopefully that will do it because a one piece toilet flush valve
needs a special wrench,to remove it, that you use with a ratchet. If you buy a new
flush valve, it comes with the wrench (glorified piece of plastic) and
is not too difficult to get the flush valve out. you can get a replacement at http://www.plumbingpartsdepot.com/ They do mail order, too. All you need is the
toilet type - a four digit number embossed in the tank starting with a
2. hope this helps but if you need anything else just ask:)
Often I change the flapper to get the toilet flapper to stay up longer, giving a longer flush....
Check for a generic flapper that wiill work with the toilets you installed...
