Hello. Please make sure your telephone line is plugged into the correct outlet.
Most fax machines typically allow you to plug the line (the cord that goes from the fax machine to the wall jack) and and a telephone (the telephone connects to the fax machine).
In order to fax correctly, you must plug the line into the jack with a block (looks like a 'T') marked on it. Do not plug the line into the jack marked with a phone hand set marked on it.
http://gdlp01.c-wss.com/gds/0900002546/PIXMA_MP780_750_Easy_Setup_Instructions_EN.pdf
This shoulds in detail how to connect the line properly. For this printer the line cord must be plugged into the jack labelled "L"
http://gdlp01.c-wss.com/gds/0900002542/PIXMA_MP750_780_Quick_Start_Guide_EN.pdf
This will show you how to actually send the fax. On your PDF View select page 42.
