SOURCE: Bios Password
Hi there.
1. Turn the computer OFF, if it's on.
2. Remove the memory module cover, on the bottom of the computer.
3. Check the configuration of memory modules in the two sockets. It's
necessary to have a memory module present in the outermost socket only.
4. Carefully peel back the black Mylar film. Pull this film to the side enough to expose the B500 solder pads. Do not remove the film completely, because it may be difficult to re-attach it correctly.
5. Short the B500 solder pads on the system board. Needle-nose pliers or a flat-blade screwdriver works well to short them.
6. While continuing to short-circuit the solder pads, turn the computer
on, and continue shorting the pads until the Toshiba Logo Screen appears. then remove the short.
7. Re-position the Mylar film over the system board.
8. If you removed a memory module, turn the computer OFF, then re-insert it.
9. Re-attach the memory slot cover.
10. turn on computer, if it boot password has been removed.
Good luck and thanks for using Fixya!!
