After completing full wash cycle the dishes are not clean.
SOURCE: no water getting through hearing
clogged supply line or clogged inlet filter or crimped supply line or supply line shut off valve turned the wrong way.
SOURCE: There are no error codes
Lower washer not working but upper washer is. This is due to the dishwasher thinking it is on half load. the sensor is faulty and you need to replace the whole unit (water circulation pump). However if like me and your not bothered about having a half load and always use both trays on your dishwasher you can fix it. remove the dishwasher unscrew the side panels and remove, unscrew the bottom panel. Tilt it on its back and then unscrew the feet and remove the bottom panel. There you will see the water circulation pump. On the top is a sensor with 2 white and 1 orange wires going to it, unscrew the sensor and underneath remove the white plastic valve/flap and its supports. with the valve/flap removed replace the sensor and build it back up. Now the water will flow through both cambers (upper and lower).
