Just purchased a Frigidaire FEFL67HC range, and the plate at the back of the unit isn't recessed to accommodate the plug and outlet box. Consequently, the unit stands 3-4 inches away from the wall. My old range sat flush with the wall, and I'd like the new one to do the same. I'm tempted to get out the tin snips, but the unit has been in my house about an hour and who wants to cut a hole in the back of a new appliance? Does any Frigidaire unit have a rear design with recess to allow for plug-in and use while still sitting against the wall? Are there any other solutions or parts to order that could fix this?
The oven temperature sensor on your Kenmore range is a one-piece unit that mounts to the rear oven wall with a mounting plate. The sensor is not difficult to change. You will need to dismantle the rear panel from the oven to access the mounting plate. Most appliance repair shops will have replacement sensors. It is a good idea to take the old sensor with you along with the model number of your oven. This way you will be sure to get the correct replacement sensor for your oven.
Unplug the Kenmore oven power cord from the wall outlet. Move the oven range away from the wall so that you can access the back of the unit. (Ask a friend to assist you to move the oven. if necessary.) The oven may use an anti-tip bracket on one of the rear legs. Push the oven toward the back wall to release the leg from the bracket in the floor. Tilt the back of the oven toward you, and pull the oven forward.
Remove the screws that secure the back panel to the oven with a Phillips-head screwdriver. Pull the back panel away from the unit and set the panel out of the work area.
Locate the mounting plate for the oven temperature sensor on the upper right side of the back of the oven. There will be a single wire coming from the back of the mounting plate and the wire mounts to a clip.
Follow the wire to the connector on the other end. Pull the connector on the wire to disconnect the wire from the wiring harness.
Remove the two screws that secure the mounting plate to the rear of the oven with a Phillips-head screwdriver. Pull the temperature sensor straight out of the oven. Unclip the sensor wire from the mounting clip.
Take the oven temperature sensor to an appliance repair facility to purchase a replacement. Insert the sensor end of the temperature sensor through the hole in the back of the oven. Slide the sensor all the way until the sensor mounting plate is flush against the oven. Secure the sensor with the two mounting screws.
Connect the sensor wire to the connector by pushing the connector until it locks in place. Snap the wire inside the retaining clip.
Place the back panel back over the rear of the oven and secure the panel with the retaining screws. Slide the Kenmore oven back into its working position and plug the power cord into the wall outlet.
