Si la pantalla de la lavadora Hitachi SF-P140XWV parpadea, es posible que se haya generado un c?digo de error. Para identificar el c?digo de error, desconecta la lavadora de la toma de corriente y espera al menos 30 segundos. Luego, vuelve a conectarla y presiona el bot?n de encendido para escanear los c?digos de error. Una vez que se haya identificado el c?digo de error, sigue las instrucciones del manual para solucionar el problema. Si el c?digo de error no se puede identificar o el problema no se puede solucionar, comun?cate con el servicio t?cnico para obtener ayuda.
F9 can happen when have wiring shortage,please do checking for wiring especially at bottom of drum maybe have wiring was shortage when have insulation tear or cut,just fix it reconnect by terminal connector or solder it and apply electrical insulation tape,hope this information can solve your problem thanks
if you have Hitachi nw-d8ax f1 error check water sensor
f3 error check rinse filter f9 error do not know where the error but I did repaired, remove back panel and right hand side inside polithine cover find blue connector its with 2 wires remove it and switch machine it will give f3 error with sound reconnect the socket its started working
mail me if yours working I will give you more tips [email protected]
cheers
