Took the cover panel off the bottom of the light bulb but cannot get the light bulb out?
Put the bulb of microwave down . and then install a new bulb on it .before do these .you should turn off the switch .
home light bulbs
SOURCE: how to change light bulb under microwave
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
The first step is to unplug the oven before changing bulbs!
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. It's at http://207.234.249.73/mwd/ge_lamp_replacement.jpg
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
http://www.microwavedisplay.com
SOURCE: JENN Air bulb replacement problems
We see (and repair) this a lot. The problem is indeed on the control panel, which
we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At
our site, we have a video available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament
shorts, or when the bulbs are removed or installed without first
unplugging the oven from the power line. Either can cause such a
failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
[email protected]
SOURCE: Replacing GE Spacemaker Light Bulb inside Microwave Oven...
Here is the GE download page for your manual. Page 35 of your manual gives the light bulb replacment instructions.
http://genet.geappliances.com/DocSearch/Dispatcher
