"Cars & Trucks" is not the correct place to post your question for your Xerox XC1044 Copier. However, I can tell you that the heating element in your drum assembly is most likely defective. That is why the toner is not sticking...it is not getting hot. You will have to replace your drum assembly to fix it.
HINT: on an older copier/printer like the XC1044, it is usually just as expensive to replace the drum assembly as it is to buy a new copier/printer. You should probably shop around before putting any money into it.
although I placed my question in the WRONG section of your website, the solution was right on point about my laser copier problem. I want to thank you very much for your help and please keep up the good work. I/we appreciate your help very much.
