Spins very fast, and I don't know where to start. Want to use turntable again, if I can fix speed problem
Direct Drive turntable's have electronically controlled motors with complicated systems to keep them at the right speed.
My guess is that there could be a power supply issue that feeds one of the motors that is sending a much higher voltage to it. But that's just a guess. You might want to look around for the service manual for it to see how the motor is controlled.
SOURCE: Technics 1200 MK2 displaying irregular speed to include dragging and slowing
It sounds like the pitch slider needs to be replaced...
Mikey's Hook-up
88-90 North 6th
Brooklyn, NY 11211
Cover insured UPS charges both ways and you will get sorted.
SOURCE: Ion turntable speed problems
Turn the tturntable over, there is a speed control pot on the bottom
SOURCE: direct drive turntable will not rotate
If it does not rotate, more than likely the belt has either come off, or is broken. Lift up the turntable platter, and you'll see what the issue could be. The platter just lifts right up.
- OPTiC
Turntable Technician
SOURCE: Sony PS-LX250H turntable speed adjustment on underside, how??
Great detective work.
Let's collaborate on this for the benefit of others who may have the same problem.
L.IN should be the point at which the Lead-In groove on the LP would be, where the tonearm will drop to play an LP
RET should be the point at which the tonearm will lift up and RETurn to its rest at the end of the LP
That leaves us with SW. If your source is right this will affect the Speed. I can't imagine what the W stands for.
Since this turntable lacks the traditional strobe light and dots along the platter rim for determining if it's on target speed-wise we have to improvise and make a Strobe Disc.
It has radial marks on it and you place it on the turntable like a record. The lights in your room running at 60hz will make it appear to be stationary if the speed is correct; slowly creeping CW if too fast; CCW if too slow.
Here's a link to a PDF from which you can print your own disc... http://www.extremephono.com/ftp/60Hz.PDF
Here's what you do. Lay the trimmed Strobe Disc on top of a record while it's playing one of the outer tracks. This is because the stylus imparts some drag so we want to factor it in.
Then adjust the screw exactly one turn Clockwise and note how the speed has changed. Trial and error should get you to where you want to be.
i sent mail them they sent me this. they gave me adress in my country and try to mail them and ask thier shop in your country or city.
pls rate this.
Thank you for your message.
Unfortunately, this device is too old and we are not keeping archive for a so long time.
Try to contact our distributor in Turkey who will perhaps be able to help you:
ERTEKIN
ELECTRONIK TIC VE SAN A.S
GALIP DEDE CAD NO 113-115
80020 KARAKOY
ISTANBUL
Telephone: 90 212 293 93 90
Fax: 90 212 249 3512
E-Mail: [email protected]
WWW: www.ertekin.com.tr
Regards,
Philippe Hautemaison
D&M Professional
T: +33 (0) 141 38 32 50
F: +33 (0) 141 38 01 10
-----Message d'origine-----
De : EN CONTACT FORM [mailto:[email protected]]
Envoyé : jeudi 28 mai 2009 20:51
à : info
Objet : D&M Pro website Enquiry | Marantz Fully Automatic Direct Drive TT530
Address: istanbul
Town: istanbul/turkey
Phone: +905059674232
Subject: Marantz Fully Automatic Direct Drive TT530
Message:
i need manuel of Marantz Fully Automatic Direct Drive TT530
where i can find ? i tried your website i didnt find. can you help me ?
This message has been generated by the contact form on dm-pro.eu | 05-28-2009 07:50:36 PM
No external adjustment other than strobe. No adjustments on underside of housing
turn TT upside down, unscrew bottom cover.you will see two variabile resistors( electronic part, you can insert little screwdriver inside).one is for 33, and other for 45 rpm. look at the strobe light and turn resistor with little screwdriver until dots on your strobe are still.have ht-355 and had the same problem. good luck
I have the same problem with my HT-355 not sure which resistors is for what speed. can someone tell me please and what way should i turn the resistor ?
