Question about Kia Vehicle Parts & Accessories
Replace wheel bearings on a kia rio
Instructions for replacing front wheel bearings
6ya staff
SOURCE:
Anonymous
SOURCE: Need to replace a rear wheel bearing, can't even get the hub off!!!
pull off rim. there is a cap in the center of the hub that you will have to tap/pry out with a screwdriver, then remove bolt and slide hub off.
thats how i fixed mine.
Posted on May 13, 2009
defadad
Harry Goodwin
  • 353 Answers
SOURCE: need instruction manual/schematics for replacing 2005 kia rio driver side rear wheel bearing. i've got the wheel/hub/bearing off, not the inside ring to the bearing. i need to know how to replace it .
clean all the grease if there is any out of the hub, turn the hub over and using a drift and hammer strike the shell from the back edge working around the shell as you go, should not take too much to remove it but you will need a bit more than a tap with the hammer.
Hope this has helped you
Posted on May 22, 2009
Anonymous
  • 957 Answers
SOURCE: Car jerks to left w/no warning
My opinion, not a good car. But that is a different story. It would be easiest to bring the car in for an alignment. The technician will tell you what the car needs to do the alignment. But if you want to do it yourself then you will need to inspect all the steering componants (tie-rods,struts, lower ball joint, wheel bearings, brakes, wheels, tire wear,tread pattern, and tire pressure, and lug nuts (loose or overtightened). Good luck.
Posted on Jun 01, 2009
fingaz22
michael schultz
  • 1068 Answers
SOURCE: I have a 2001 kia rio, we have replaced front
well not sure what you mean by one piece assm. becuase all front wheel drive cars require one shaft and two c/v joints on either end.
but i think i have a hunch of the problem and them most common cause for failure after a replacement is over tighting of the axle nut. what happens is it crush's the bearing and cut's it's life.
Posted on Apr 20, 2010
edwardjwoods
Ed Woods
  • 372 Answers
SOURCE: how to replace front tire broken wheel studs on a
you take the brakes off and you will be able to hit the broken stud with a hammer and push it out.
Posted on Nov 30, 2010
Is it possible to remove and replace front wheel bearings with out a press
In order to remove the front wheel bearings without press hub off the bearing and then the bearing out of the knuckle. To do the first step need a a Support Bridge.It is a special tool. Make bridge and use a general bearing pulled kit to replace bearings. use a "Front Wheel Drive Bearing Removal Adapters Puller Pulley Tool Set Kit" .To replace the bearing, remove front CV shaft taking care not to move the CV shaft too far out .
Nov 06, 2015 | 2002 Kia Rio
How to remove a front wheel bearing on a 2001 kia rio
Does 2001 kia rio need to have a spacer for the driver side wheel bearings
Aug 25, 2012 | 2001 Kia Rio
Hello, I have problem on my 2004 Kia Rio, with right rear wheel bearing, it stuck and has noise. what you can suggest to do?
Get all wheel bearings replaced.A car of that age shouldn't have wheel bearings failing so early.Try getting something aftermarket as Kia parts are not that reliable.There are heaps of complaints about this car if you google.
Aug 04, 2011 | 2004 Kia Rio
Does the 2004 kia rio front wheel bearings require scheduled replacement? Thank you
Not normally, they are replaced on an as as when basis.
Checked during service, if found to be loose/failing, then replaced.
Also replaced if known to be warn, usually signified by a rumbling noise from the area
of the offending wheel.
Dec 09, 2010 | 2004 Kia Rio
I have a 2001 kia rio, we have replaced front wheel bearing a combined total of 12 times and it only has 81000 miles on it. one are the other goes out about every 10000 miles.can we replace the older axle...
Apr 20, 2010 | 2001 Kia Rio
How do i change a front wheel barring in a 2001 kia rio
Remove the wheel, remove the cap, remove the pin pry out the bearing, make sure you repacek the new bearing with wheel bearing grease.
Jul 01, 2009 | 2002 Kia Rio
Need instruction manual/schematics for replacing 2005 kia rio driver side rear wheel bearing. i've got the wheel/hub/bearing off, not the inside ring to the bearing. i need to know how to replace it .
May 22, 2009 | 2003 Kia Rio
Need help replacing front hub
Here's the steps....getting some pics for you....hang on a minute or two.
Front Hub Removal & Installation To Remove:
  1. Remove steering knuckle.
  2. Using a suitable slap hammer, remove wheel hub assembly.
  3. Using a suitable bearing press, remove outer bearing, oil seal, outer bearing race and preload spacer.
  4. Remove inner oil seal, inner wheel bearing and inner bearing race.
NOTE: It is not necessary to remove dust cover (back plate).
To Install:
  1. Using a suitable bearing press, install bearing races in steering knuckle.
  2. Pack the bearings and hub area with lithium grease.
  3. Install inner bearing in steering knuckle.
  4. Lubricate lip of NEW inner seal and press seal into knuckle.
  5. Install preload spacer into bore.
  6. Install outer bearing into bore.
  7. Lubricate lip of NEW outer seal and press seal into knuckle.
  8. Using an appropriate tool, support inner wheel bearing and press wheel hub into knuckle with a force of 2500kg.
  9. Install NEW inner seal.
  10. Install knuckle assembly.
May 13, 2009 | 2004 Kia Rio
Vehicle Parts & Accessories Logo
82 people viewed this question
Top Kia Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Cameron Lewis
Cameron Lewis
Level 1 Expert
Kardoc
Are you a Kia Vehicle Part and Accessory Expert? Answer questions, earn points and help others
