SOURCE: SONY KV-27FV310: UPPER HALF OF SCREEN IS BLACK
You have a vert sweep problem and unless you know how to trouble shoot this cuircit bring it to a pro. I found out mostly in these sets that the vert output IC is bad.. Also sometimes the b+ filter cap off the fly is leaky and made the IC to fail. Another thing is Im surprised to hear you got a pic with the vert failure and a bright line in the pic!! This could be a big problem when the sets fixed so dont run it too long like this. It could burn a line all the way across the screen and you will see a dark faint line in your pic because of this. BE CAREFULL!!
SOURCE: Sony TV - Loss of half the picture
sarge, it sounds like the vertical output IC went bad on you. If it was a bad connection or a bad capacitor, your picture would have been a straght line across the screen. They call the output section of the IC a push-pull type of amp, so the top half of the sweep IC went out. If you have had some soldering experience, and or experience with solid state repair, locating the bad IC and replacing it is no big deal. If you havent, stay safe and call in a pro to assist you in this repair, as there is alot of high voltage inside this puppy that is still present even if the set is unplugged. It should not cost an arm or a leg to repair this set. An honest repair on a set like this if you take it in should not exced 125 to 150 bucks. Good Luck PS Please dont forget to rate this thread.
SOURCE: I have a Sony FD
The set has a vertical deflection problem, the vertical ic and a few capacitors will need to be replaced to restore the tv to normal function.
