Melts all the ice after it makes about a half bucket
SOURCE: ice maker not making ice
Check the cam wheel beneath the front cover of the icemaker it is probably not turning.
SOURCE: Kitchenaid ice maker
Is it sticking all the way up in off position?If so there is a redesigned arm to stop this problem. Instead of just a wire arm, it has a plastic flap on the bottom that hinges. This keeps the arm from jumping into the off position when it cycles. Any whirlpool/kitchenaid servicer should have one and show you how to replace it. Takes just a few seconds. If it is sticking half way down or lower, then it is binding up somewhere. You should be able to raise it about 2" and it fall freely back into place. Post back if this is what is happening.
SOURCE: KitchenAid Superba ice maker not dispensing ice
this is not a solution, but an explanation- our repair man said that there is a line (tube) containing electric wires that passes from the frig to the door at the bottom of the door, near the hinge. for what ever reason, the line has broken, thus keeping the electric from getting to the motor that dispense ice and water- solution= $700 for a new door; we'll do without
SOURCE: GE Monogram Ice Maker ZDI15 makes an ice sheet but does not drop or melt the sheet into cubes.
Below is a couple og links. One is for the user manual and the other is for parts should. Sounds to me the cutting grid is not getting hot and cutting the ice into cubes. PDF below, click link
http://imgs.ebuild.com/xCat/ebuildWebB/15?ObjectID=1105&Variant=Original
For parts or free answers go to this link and enter your model number into the search feature. Model ZD115C That will take you to a page with pictures and part numbers. The home page you may call or email for answeres. I did see a control board and for some reason the cutter is not heating this will cause the problem. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
it goes into defrost and melts all the ice and then it stops making ice all together
