My LCD TV recently started to emit a smell of what seemed like burning electronics. I immediately unplugged the device and, after waiting near a full day, took off the back of the TV to see if could locate the problem. I didn't see any obvious damage, but the smell was still there. It seemed to be coming from from an area with multiple splotches of white adhesive on the capacitors (?). To double check, I rubbed a finger only atop the glue and the smell transferred, quite strongly. The display and sound on the television work fine still (I've tested after), but the glue smell still lingers. My question is this, I suppose, as it seems nothing else is damaged or emitting that smell, but something is clearly making the glue hot enough to smell so strongly, is there any hope that I've caught this overheating early enough to stop? Before something is actually ruined? The TV is about three years old, so it's not that "new electronic" smell I've spotted some people address. The ventilation around the TV hasn't been particularly ideal in the room it is located in. Not to mention other electronics that get rather hot are located in the same room. (Xbox 360, Playstation 3, computer.) Any help would be greatly appreciated, as it's out of warranty and I'm not currently in a position to purchase a new TV. Let alone one as nice as the one in question.
Your tV need service. Never swith ON this set as it is now. Contact the authorised service center for LG.
This does not help me.
If you are so sound enough in electroncis, try to download the repair book to this model LG set from net, and follow it. Just remember, it will not be easy as you repalce a bulb in a holder. I've the repair book to this Tv, but, I can't send it to you by this window, and if I ahve to send it to by any other means, it will cost more to me. No body here to bare my expenses. OK.
SOURCE: Plasma TV smell?
i had the same prob and thought it would burn off. It didn't after a month. Read the comments and tried the plug direct into wall socket plus i washed off the tv surface several times. Now no smell. Not sure which action cured the problem but i'm now happy. It was so bad i had to leave a window open and at times i would gag from the smell.
SOURCE: LG LCD TV model 42LH70YR switches on and off continuously
[email protected] PLEASEEE!! I`VE THE SAME PROBLEM! MY 42LH70YR SI CONTINUOUSLY TURNING ON / OFF !!
PLEASE IF SB KNOWS HOW TO RESOLVE IT SEND ME AN E-MAIL.
IM FROM URUGUAY
If you notice a burningsmell in your washing machine, the cause could be any number of things. Regardless, this is one smell you shouldn't ignore. It's important to quickly diagnose the problem and find the solution.
The "Burning Belt" Smell
Older, top-loading washing machines use a belt drive to transport energy from the motor to the transmission and pump. The belt can prevent costly repairs to the motor or transmission by slipping, stretching, or breaking if there is a malfunction in the machine. If the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell.
The solution is actually quite simple: you need to replace the drive belt on your washing machine. You can call a repairperson or, if your washer is under warranty, the manufacturer. If you or someone you know is handy, you can replace the belt yourself. The belt is located either from the back access panel or from the underside of the washer.
Most new washing machine models are "direct drive." This means they do not use a belt. The motor is directly connected to the transmission. If you have a direct drive machine and your washer smells like it is burning, read on.
Electrical Problems
If your washer smells and you have a direct drive machine, it may be the motor, transmission, or both. If these are shot on your washing machine, the result may be an electrical burning smell. Both are necessary to run your washing machine and can be costly to repair. The first thing to do if you notice an "electrical" smell in your washing machine and not a "rubber" burning smell, is to unplug the machine and call the manufacturer or a repairperson.
An electrical burning smell may also be caused by a water leak coming into contact with electrical wiring. Both are major concerns and should be addressed immediately. A water leak can cause structural damage in your home and can short out the electrical wiring in your washer and cause additional damage to the machine.
Other Causes
Another more likely cause of a burning smell in your washer is overloading. Adding too many clothes to your washing machine can stress the motor or transmission, causing them to overheat or malfunction and emit a burning smell. For top load washers, overloading can cause the agitator to freeze or malfunction, stressing the drive belt and causing friction, which could emit a burning rubber smell.
To prevent overloading, know the size of your washer. They are measured in cubic feet. In addition, know how many towels, pants, shirts, and other items you can safely load. When it doubt, do smaller loads. Not only will this prevent overstressing the machine, it will also ensure clothes are thoroughly cleaned and rinsed.
I'd prefer to do the service myself.
