Size of fuel line mc 225163
SOURCE: ryobi 2 cycle gas trimmer 705r/725r
add your own new nipple with some expoy or replace with a new gas tank if you can find one. go to any auto parts store and buy a pack of nipples in various sizes, that's what iv'e done being uable to find another fuel tank
SOURCE: McCulloch MAC2815 string trimmer fuelline connections
you have 50/50 chance of getting right you wont hurt if wrong try till unit works!!! :)
SOURCE: I have a Craftsman trimmer mod# 358795121. What size fuel lines.
Sears has ample parts for repair.
SOURCE: Fuel line size for troy built TB20CS weed eater
You probably have found the solution by now I would assume... TB won't tell you this because they want you to buy their stuff..
You probably are looking at the 0.08" diameter that's just a bit smaller than the 3/32". Hope this helps....
SOURCE: What is the fuel line size for Troy Bilt TB525CS Trimmer?
Yes, something special to know. If the new fuel line is going into the gas tank, be sure to cut a steep angle on the end of the line going into the gas tank. This will allow enough of the line to get into the tank where you will be able to grab it thru the gas fill opening with needle nose pliers and pull it thru.
Testimonial: "Thanks for the tip, I will try that when I find out the fuel line size."
